senkoo
Petalinux Project overrides edited files
My name is Senna. I am working on a project with ZC702 dev kit. But my board does NOT have a phyiscal ethernet switch.
So i made changes in xilinx_emacps.c and fixed_phy.c so i wanted to test them.
But when i put them in: /data/projects/aet/senkoo/Ets-Prg/Firmware/ets-prg-firmware/petalinux/ets-prg$ cd build/tmp/work-shared/plnx_arm/kernel-source/drivers/net/ethernet/xilinx/
They seem to get overriden. When i run: petalinux-build and program the kernel to SPI flash and boot. The log does not show my prints i put in the file. So i was wondering do i need to place the modified files somewhere else where it can include them or i need to set some configuration some where?
I also included the files for clarification.
Thanks in advance.
Greetings,
Senna
aravindb
Hi @senkoo
You should not modify anything that build directory, that will be overwritten  every time when it builds.
You can follow below methods, if you would like to add any changes in driver, this will be reflected in your code while building and you can check in the board.
Method1:
1. Download same kernel tag from repository
2. modify your changes and create patch using git
3. follow the steps mentioned in this link :http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips section "Patching the Linux Kernel of a PetaLinux Project "
4. petalinux-build
Method 2:
You can build kernel as External kernel source option
Build steps for External source using petalinux:
1. petalinux-config and go to -> Linux Components Selection ---> linux-kernel (ext-local-src)
External linux-kernel local source settings --->/aravind_working_dir/source_code/my_xlnx (EXternal linux-kernel local source path)
2. Go to -> Auto Config Settings and select Specify a manual device tree include directory and enter the path to the new kernel include directory.
Auto Config Settings ---> [*] Specify a manual device tree include directory
(/aravind_working_dir/source_code/my_xlnx/arch/arm64/boot/dts/include) Manual device tree include directory
3. Save and exit petalinux-config
4. Do a petalinux-build
Thanks & regards
Aravind
aravindb
Hi @senkoo
Method1:
4. petalinux-build
Method 2:
Thanks & regards
Aravind
senkoo
HI @aravindb,
Thank you so much ! :)
Cheers
