ambrown0430
Petalinux SD Boot freeze 2020
I am trying to boot a custom board from an SD card. I generate the necessary files, according to the petalinux user guide and the embedded tutorial, but the boot process freezes at the first stage boot loader. Any idea of the source of this? I have the uart and sd enabled in the .xsa file.
stephenm
Can you share the BIF image you used, or can you share how you created the boot image? Is there a uboot image here?
If this is all correct, then can you test the DDR? The uboot boots from DDR so, if there is an issue with the DDR, Then you will see issues here.
Can you see the blog series below where I discuss how to debug the arm trusted firmware and uboot in Vitis:
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/PetaLinux-Image-Debug-Series-Debugging-ARM-Trusted-Firmware-and/ba-p/1151076
ambrown0430
Update: I attached a screenshot of where it freezes
katsuki
Hi @ambrown0430
Will SD boot succeed if you create it with a standard flow as shown below?
$ petalinux-create -t project --template zynqMP -n myboard
$ cd myboard
$ petalinux-config --get-hw-description=<XSA dir>
$ petalinux-build
$ petalinux-package --boot --fsbl --pmufw --fpga --u-boot --force
copy BOOT.bin, boot.scr, image.ub to SD card.
or
Will SD boot succeed for baremetal app(hello world) instead of Linux?
Thank you.
Don't forget to Reply, Kudo, and Accept as Solution.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
stephenm
ambrown0430
The DDR was not configured correctly in Vivado. Once configured correctly, all issues were resolved.
