Observer hemsingj
Petalinux SDK eclipse plugin crashes Xilinx SDK
Hi everyone,
I've got Petalinux 2013.0 and XIlinx 14.4. I've installed and reinstalled the eclipse plugin, but when I have both the xilinx settings.sh and /opt/petalinux/settings.sh sourced, xsdk quits immediately after opening. The console spits out "failed to read data from platform listing" 3 time before it quits.
Any ideas?
Observer aclark
Re: Petalinux SDK eclipse plugin crashes Xilinx SDK
Are the permissions correct in your /opt/* directories? If you're running the SDK as a normal user (not root) then you should have read permissions. Just a guess though. Before changing the permissions try to run as root. Again, just a guess. Good luck.
