xmacur06
Petalinux Terminal/console change colors
Hi all,
I am newbie in Petalinux ... and I would like now, where can I change colors for my terminal/console?
I would like to have colors  as demo Linux from Avent microzed (on the picture).
Jachym
sandeepg
Hi @xmacur06 ,
Below is the steps you need to follow.
1. Create a base-files directory
$ mkdir <plnx-proj-root>/project-spec/meta-user/recipes-core/base-files
2. Create base-files_%.bbappend and
$ vim <plnx-proj-root>/project-spec/meta-user/recipes-core/base-files/base-files_%.bbappend
3. Add color to terminal profile depending on what you need refer https://wiki.archlinux.org/index.php/Color_output_in_console
https://www.tldp.org/HOWTO/html_single/Text-Terminal-HOWTO/#colors
do_install_append () {
	echo "alias ls='ls --color=auto'" >> ${D}${sysconfdir}/profile
4. Rebuild rootfs
$ petalinux-build -x cleansstate
$ petalinux-build
Sandeep
sandeepg
Hi @xmacur06 ,
4. Rebuild rootfs
$ petalinux-build
Sandeep
