Petalinux Unsupported RHEL 7.6
I have installed Petalinux 2019.1 on a RHEL server 7.6 , however the settings.sh script prints "WARNING: This is not a supported OS", however the Petalinux 2019.1 userguide; states RHEL sever 7.6 is supported.?
sh-4.2$ cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.6 (Maipo)
sh-4.2$ source /var/data/petalinux_2019_1/settings.sh
PetaLinux environment set to '/var/data/petalinux_2019_1'
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution
sh-4.2$
So is the warning fromt he script incorrect or the documentation?
Tim
Re: Petalinux Unsupported RHEL 7.6
Hi @tmonaghan84
You can ignore this warning message. We will correct this in our future release. As said in Document, RHEL 7.6 (64-bit) OS is supported for 2019.1 petalinux
Best Regards
Shabbir
