Visitor trjeppsdl
Petalinux Zedboard: Understanding peek/poke, mmap, GPIO(emio).
I'm trying to get a better understanding of how to access Zynq's I/O peripheral registers in petalinux. The ultimate goal is writing drivers, but I want to start simple.
I've routed 16 bits of GPIO(emio) to the PMOD connectors on my zedboard, and in a bare metal project, I'm able to control them using the GPIO bank 2 registers (DIRM2, OEN2, DATA_2_RO, MASK_DATA_LSW) as detailed in the Zynq-TRM.
Next, I exported my bitstream and hardware definition files, and built a petalinux 2014.4 image based on them.
I assumed that I would be able to use the peek/poke application to access these same control registers, but all reads (peek) return 0's and nothing happens when I write (poke).
As i understand it, peek/poke use the mmap() function to map an address range from /dev/mem into userspace, but my knowledge of linux memory mapping is very limited, and I'm obviously missing something.
So, why doesn't this method work, and what do I need to do to get direct read/write access to the Zynq's GPIO bank 2 registers?
From there, I'd like to write a loadable char driver to do the same thing.
Re: Petalinux Zedboard: Understanding peek/poke, mmap, GPIO(emio).
Somewhere in the SLCR is a register (APER_CLK_CTRL, IIRC). Some bit in it controls the clock gate for that clock.
Basically your approach is correct and works. But likely, the clock for GPIO is not enabled (grep -i gpio /sys/kernel/debug/clk/clk_summary). Things should work if you enable the GPIO-related clocks.
Unless you just do this as an exercise, there are already GPIO drivers available: http://www.wiki.xilinx.com/Linux+GPIO+Driver
Visitor trjeppsdl
I think you're right about the clock.
grep returned this line from the clock summary:
gpio_aper       0         0        111111110          0
From this line of my device tree, the gpio clock is:
clocks = <&clkc 42>;
This document confirms that clk 42 is in fact gpio_aper
https://www.kernel.org/doc/Documentation/devicetree/bindings/clock/zynq-7000.txt
The clocks section of my device tree:
            clkc: clkc@100 {
                #clock-cells = <1>;
                compatible = "xlnx,ps7-clkc";
                ps-clk-frequency = <33333333>;
                fclk-enable = <0xf>;
                clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x",
                        "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x",
                        "dci", "lqspi", "smc", "pcap", "gem0", "gem1",
                        "fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1",
                        "sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1",
                        "dma", "usb0_aper", "usb1_aper", "gem0_aper",
                        "gem1_aper", "sdio0_aper", "sdio1_aper",
                        "spi0_aper", "spi1_aper", "can0_aper", "can1_aper",
                        "i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper",
                        "gpio_aper", "lqspi_aper", "smc_aper", "swdt",
                        "dbg_trc", "dbg_apb";
                reg = <0x100 0x100>;
How do I go about enabling gpio_aper?
The article below covers the steps of configuring, building, and loading PetaLinux (2015.2) for Zedboard. With demo Linux application tested(gpio-demo).
http://embeddedcentric.com/embedded-operating-systems/
EmbeddedCentric.com
