Visitor tahoe250
Petalinux-Zybo-Z7-20-2017.4-3.bsp Zybo-20
Hello everyone,
I am new to Petalinux.  I have couple of questions.
 I am using PetaLinux SDK version "2018.3 when I do  petalinux-config --get-hw-description=../
   i get the following:
       WARNING: Your PetaLinux project was last modified by PetaLinux SDK version "2017.4",
      WARNING: however, you are using PetaLinux SDK version "2018.3".
      Please input "y" to continue. Otherwise it will exit![n]y
When config manager comes up I hit ESC then this prints out
INFO: Getting hardware description...
INFO: Rename design_1_wrapper.hdf to system.hdf
[INFO] generating Kconfig for project
[INFO] menuconfig project
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating machine configuration
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating kconfig for Rootfs
Traceback (most recent call last):
  File "rootfs_config.py", line 315, in <module>
    parse_args(sys.argv[1:])
  File "rootfs_config.py", line 290, in parse_args
    extract_packages_dot(packages_user)
  File "rootfs_config.py", line 257, in extract_packages_dot
    with open(packages_dot,'r') as fp:
IOError: [Errno 2] No such file or directory: '/home/iaguilar/Desktop/ZyboLinux/zyboBase/project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend'
ERROR: Failed to generate rootfs /home/iaguilar/Desktop/ZyboLinux/zyboBase/build/misc/rootfs_config/Kconfig.user
ERROR: Failed to config project.
ERROR: Get hw description Failed!.
 Do I have to upgrade the bsp to PetaLinux SDK version "2018.3"? Is that why these errors are occurring ?
Scholar watari
Re: Petalinux-Zybo-Z7-20-2017.4-3.bsp Zybo-20
Hi @tahoe250
Since you use bsp for 2017.4 and tool version is 2018.3, it is occured.
Would you use bsp for 2018.3 ?
Visitor tahoe250
thank you for your reply,
I am not sure what you are asking.  That is the latest BSP for that board.
Scholar watari
Hi @tahoe250
According your subject "Petalinux-Zybo-Z7-20-2017.4-3.bsp Zybo-20" on your post and your log, you use bsp as version 2017.4.
So, you must make sure it and use same version between bsp and petalinux.
Visitor tahoe250
thank you watari,
There is no way to upgrade the bsp?
Scholar watari
Hi @tahoe250
Would you change petalinux version to 2017.4, if you don't upgrade bsp ?
Visitor tahoe250
watari,
Thanks again.  I am gonna give that a try.
