Petalinux add recept for nmap
Hi everyone!
For my ZYNQ Ultrascale+ MPSoc Application i want to add nmap to petalinux-config.
I am working with Ubuntu 16.04 and petalinux 2018.2 and i get petalinux running on Ultrascale+. My next step is to add a recipe to petalinux for nmap.
What would be a propper way? I have the sources but not idea where to start with a yocto recipes to it.
Can anyone give me a more detailed guide as the AR# 67160 - How to add packages to PetaLinux?
Voyager
Voyager
Re: Petalinux add recept for nmap
Use yocto meta-security layer
$ git clone -b rocko git://git.yoctoproject.org/meta-security
$ petalinux-config
$ petalinux-build -c nmap
Voyager
Voyager
$ petalinux-config
Thank you very much! Thank you, it's quite easy, straight forward and finally it works.
In a more general sense and for understanding, how would you write the recipe yourself?
Hi @karl_hab,
Refer Yocto Project docs for writing recipes https://www.yoctoproject.org/docs/current/dev-manual/dev-manual.html#new-recipe-writing-a-new-recipe https://www.yoctoproject.org/docs/1.8/bitbake-user-manual/bitbake-user-manual.html
Sandeep
Hi @sandeepg,
Thank you for your replay, I'll try it right now.
