Petalinux adds '-xilinx' suffix to kernel release number after building the kernel from external source.
I grabbed the source of version 4.14.0 from https://github.com/torvalds/linux. After building the kernel in Petalinux and booting from it, command `uname -r` returns 4.14.0-xilinx.
When I build a module against this kernel, make returns:
make -C /usr/src/linux-source-4.14.0-xilinx M=/home/test/apps/dma modules_install
make[1]: Entering directory '/usr/src/linux-source-4.14.0-xilinx'
DEPMOD 4.14.0
make[1]: Leaving directory '/usr/src/linux-source-4.14.0-xilinx'
So the .ko file is installed in /lib/modules/4.14.0/. But the modprobe command always try to find the file with the kernel release:
modprobe ds-axidma
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.14.0-xilinx/modules.dep.bin'
modprobe: FATAL: Module ds-axidma not found in directory /lib/modules/4.14.0-xilinx
Thus I can't install the module.
How can I solve this problem? Thank you.
Re: Petalinux adds '-xilinx' suffix to kernel release number after building the kernel from external source.
HI @fiedel
Can you please try to add extra string to CONFIG_LOCALVERSION like below in your kernel configuration file.
 CONFIG_LOCALVERSION="-xilinx"
Thanks & regards
Aravind
Thank you @aravindb.
I did all the compilation from Petalinux and I'm not quite familiar with the configuration from editing the files, so I'm not sure where to define the string. I did a search in the source directory and found the in file: components/ext_sources/linux-4.14/arch/arm/configs/xilinx_zynq_defconfig
This definition already exists. So I made it as
CONFIG_LOCALVERSION=""
After that I ran petalinux-build, boot the board with the created images. The kernel release is still 4.14.0-xilinx.
Should I define the string somewhere else, or some extra configuration is needed to make it effective?
OK. I defined the string in project-spec/meta-plnx-generated/recipes-kernel/linux/configs/plnx_kernel.cfg. Now the system booted and the kernel version seems to be 4.14.0.
Again I compiled the module:
# make
make -C /usr/src/linux-source-4.14.0 M=/home/test/apps/dma modules_install
make[1]: Entering directory '/usr/src/linux-source-4.14.0'
  INSTALL /home/test/apps/dma/ds-axidma.ko
  DEPMOD  4.14.0
make[1]: Leaving directory '/usr/src/linux-source-4.14.0'
But modprobe is not successful:
# modprobe ds-axidma
modprobe: ERROR: ../libkmod/libkmod.c:514 lookup_builtin_file() could not open builtin file '/lib/modules/4.14.0/modules.builtin.bin'
modprobe: ERROR: could not insert 'ds_axidma': Exec format error
Do I still have kernel version inconsistance somewhere?
