gongjian320
Petalinux build OpenAMP project failed!
I follow ug1186, Building the OpenAMP Linux Master or Bare-Metal/FreeRTOS Application . Do all as it said.
But I failed .
I also can't understand this statement .
gongjian320
when I use petalinux-config , It have following warning .
balkris
http://www.wiki.xilinx.com/OpenAMP+2016.1
Thanks and Regards
Balkrishan
