Petalinux build TRD 2017.2 failed
Hi I am building TRD 2017.2 for ZCU106. I have followed instructions mentioned in
Zynq_UltraScale _MPSoC_VCU_Targeted_Reference_design_ea_2017.2.pdf. I am getting following error :
cd Source/ && ( test -e Makefile.QtWebKit || /home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/sysroots/x86_64-linux/usr/bin/qt5/qmake /home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/git/Source/QtWebKit.pro QMAKE_CFLAGS+=-g0 QMAKE_CXXFLAGS+=-g0 -o Makefile.QtWebKit ) && make -f Makefile.QtWebKit
| make[1]: Entering directory '/home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/build/Source'
| ( test -e Makefile.api || /home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/sysroots/x86_64-linux/usr/bin/qt5/qmake /home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/git/Source/api.pri QMAKE_CFLAGS+=-g0 QMAKE_CXXFLAGS+=-g0 -o Makefile.api ) && make -f Makefile.api
| ERROR: oe_runmake failed
| make[2]: Entering directory '/home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/build/Source'
| rm -f libQt5WebKit.so.5.7.0 libQt5WebKit.so libQt5WebKit.so.5 libQt5WebKit.so.5.7
| linking ../lib/libQt5WebKit.so.5.7.0
| /home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-ld.gold: internal error in make_view, at ../../gold/fileread.cc:474
| collect2: error: ld returned 1 exit status
| make[2]: *** [Makefile.api:94: ../lib/libQt5WebKit.so.5.7.0] Error 1
| make[2]: Leaving directory '/home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/build/Source'
| make[1]: *** [Makefile.QtWebKit:45: sub-api-pri-make_first-ordered] Error 2
| make[1]: Leaving directory '/home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/build/Source'
| make: *** [Makefile:352: sub-Source-QtWebKit-pro-make_first-ordered] Error 2
| WARNING: /home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/temp/run.do_compile.12774:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/pranaykumark/projects/zync_eval_board/projects/trd/vcu_petalinux_bsp/work/aarch64-xilinx-linux/qtwebkit/5.7.1+gitAUTOINC+76e2732f01-r0/temp/log.do_compile.12774)
ERROR: Task (/home/pranaykumark/projects/zync_eval_board/petalinux_17_2/components/yocto/source/aarch64/layers/meta-qt5/recipes-qt/qt5/qtwebkit_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6145 tasks of which 6144 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
I am attaching the log file mentioned in the prints. Can you please help me in solving above issue
Pranay kumar
