Petalinux build cannot find the device tree files
Following the documentation for building the TRD for zcu102, I run into this error when trying to the build project.
These are the steps I have taken
cd $TRD_HOME/petalinux
% petalinux-create -t project -s zcu102-base-trd.bsp -n bsp
% cd bsp
% petalinux-config --get-hw-description=$TRD_HOME/zcu102_base_trd/sw/a53_linux/a53_linux/prebuilt --oldconfig
% cd $TRD_HOME/petalinux/bsp/project-spec/meta-user/recipes-bsp/device-tree/files/
% rm system-user.dtsi
% cp zcu102-base-dm1.dtsi system-user.dtsi
% petalinux-build
The build runs for quite sometime and runs into this issue -
| DEBUG: Executing shell function do_compile
| gcc: error: /home/nikhil/Documents/zcu102/Base_TRD/rdf0421-zcu102-base-trd-2018-2/petalinux/bsp/build/../components/plnx_workspace/device-tree/device-tree/*.dts: No such file or directory| gcc: warning: ‘-x assembler-with-cpp’ after last input file has no effect
| gcc: fatal error: no input files
| compilation terminated.
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/nikhil/Documents/zcu102/Base_TRD/rdf0421-zcu102-base-trd-2018-2/petalinux/bsp/build/tmp/work/zcu102_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.27728)
I do see that there are no files inside the ../plnx_workspace folder. My pealinux-config did not throw any errors so I am not sure what is causing this.
