Petalinux build error: zcu102+meta-adi for ad9361 +fpga manager enabled
 Hi, I worked with petalinux 2018.3.
.Firstly I built correctly project. This project contain ad9361 referance design (2019R1 branch) and meta-adi (2018_R2 branch).
Then I enabled FPGA Manager option in petalinux configuration but didn't built my project.
ERROR: device-tree-xilinx+gitAUTOINC+b7466bbeee-r0 do_compile: Function failed: do_compile (log file is located at /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.11127)
ERROR: Logfile of failure stored in: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.11127
Log data follows:
| DEBUG: Executing shell function do_compile
| pl.dtbo: Warning (reg_format): "reg" property in /fragment@2/__overlay__/axi_ad9361@99020000 has invalid length (16 bytes) (#address-cells == 2, #size-cells == 1)
| pl.dtbo: Warning (reg_format): "reg" property in /fragment@2/__overlay__/axi_dmac@9c400000 has invalid length (16 bytes) (#address-cells == 2, #size-cells == 1)
| pl.dtbo: Warning (reg_format): "reg" property in /fragment@2/__overlay__/axi_dmac@9c420000 has invalid length (16 bytes) (#address-cells == 2, #size-cells == 1)
| pl.dtbo: Warning (reg_format): "reg" property in /fragment@2/__overlay__/axi_sysid@85000000 has invalid length (16 bytes) (#address-cells == 2, #size-cells == 1)
| pl.dtbo: Warning (reg_format): "reg" property in /fragment@2/__overlay__/PERIPHERAL@ff380000 has invalid length (16 bytes) (#address-cells == 2, #size-cells == 1)
| pl.dtbo: Warning (reg_format): "reg" property in /fragment@2/__overlay__/PERIPHERAL@ff990000 has invalid length (16 bytes) (#address-cells == 2, #size-cells == 1)
| pl.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
| pl.dtbo: Warning (unit_address_vs_reg): Node /fragment@1 has a unit name, but no reg property
| pl.dtbo: Warning (unit_address_vs_reg): Node /fragment@2 has a unit name, but no reg property
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@2/__overlay__/axi_ad9361@99020000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@2/__overlay__/axi_ad9361@99020000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@2/__overlay__/axi_dmac@9c400000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@2/__overlay__/axi_dmac@9c400000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@2/__overlay__/axi_dmac@9c420000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@2/__overlay__/axi_dmac@9c420000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@2/__overlay__/axi_sysid@85000000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@2/__overlay__/axi_sysid@85000000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@2/__overlay__/PERIPHERAL@ff380000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@2/__overlay__/PERIPHERAL@ff380000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #address-cells value for /fragment@2/__overlay__/PERIPHERAL@ff990000
| pl.dtbo: Warning (avoid_default_addr_size): Relying on default #size-cells value for /fragment@2/__overlay__/PERIPHERAL@ff990000
| Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:6.15-28 Label or path axi_ad9361_0 not found
| Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:7.15-26 Label or path misc_clk_0 not found
| Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:8.15-34 Label or path axi_ad9361_adc_dma not found
| Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:9.15-34 Label or path axi_ad9361_dac_dma not found
| Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:10.15-28 Label or path psu_ctrl_ipi not found
| Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:11.15-35 Label or path psu_message_buffers not found
| Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:12.15-27 Label or path axi_sysid_0 not found
| FATAL ERROR: Syntax error parsing input tree
| WARNING: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/run.do_compile.11127:1 exit 1 from 'dtc -I dts -O dtb -R 8 -p 0x1000 -b 0 -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/../components/plnx_workspace/device-tree/device-tree -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/arch/arm64/boot/dts/xilinx -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0 -@ -b 0 -@ -i/home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/arch/arm64/boot/dts/xilinx -o ${DTS_NAME}.dtb `basename ${DTS_FILE}`.pp'
| ERROR: Function failed: do_compile (log file is located at /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.11127)
ERROR: Task (/home/esra/petalinux/2018.3/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2583 tasks of which 2544 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build device-tree
Re: Petalinux build error: zcu102+meta-adi for ad9361 +fpga manager enabled
Did you mean that after enabling FPGA manger you are facing this issue? before that, your project was built successfully.
I'm facing this issue after enabling FPGA Manager
@esraaltun Please share your log file of error which is a store at below location
Log File:
Error: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/pl-delete-nodes-zynqmp-zcu102-rev10-ad9361-fmcomms2-3.dtsi:6.15-26 Label or path axi_ad9361 not found
WARNING: /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/run.do_compile.15907:1 exit 1 from 'dtc -I dts -O dtb -R 8 -p 0x1000 -b 0 -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/../components/plnx_workspace/device-tree/device-tree -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/arch/arm64/boot/dts/xilinx -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -i /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0 -@ -i/home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work-shared/plnx-zynqmp/kernel-source/arch/arm64/boot/dts/xilinx -o ${DTS_NAME}.dtb `basename ${DTS_FILE}`.pp'
ERROR: Function failed: do_compile (log file is located at /home/esra/petalinux-project/zcu102-ad9361-2019R1-hdf/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.15907)
