Visitor selvance
Petalinux build - fails
I'm using Petalinux 2014.2  in RHEL 6.5.
I've created Hardware handoff file(.hdf) using Vivado 2014.2 in windows operating system.
I'm getting the following error while building the images.
#petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/uWeb
[INFO ] build system.dtb
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[ERROR] make[3]: *** [/opt/Tamilselvan/petalinux/exp1/build/linux/u-boot/u-boot-plnx/arch/microblaze/lib/board.o] Error 1
[ERROR] make[2]: *** [/opt/Tamilselvan/petalinux/exp1/build/linux/u-boot/u-boot-plnx/arch/microblaze/lib/built-in.o] Error 2
[ERROR] make[1]: *** [/opt/Tamilselvan/petalinux/exp1/build/linux/u-boot/u-boot-plnx/u-boot] Error 2
ERROR: Failed to build linux
Please help me on this.
Scholar trenz-al
Re: Petalinux build - fails
1 look the log files, there is more info about where it fails
2 use some existing BSP make sure it builds ok, then try our hdf
Visitor mrsouth
PetaLinux only prints general information on the terminal. The detailed build log can be found in '<your petelinux project>/build/build.log'. The error information are usually near the end of the log.
