Observer czeh@ball
Petalinux build failure - device-tree/pl.dtsi:77.34-48 Value out of range for 32-bit array element
I have very simiple design with PS and CMAC in US+ device.  The CMAC is at 0x0080000000 address space with 64k of range.  The PS interfaces to the PL with the M_AXI_HPM0_LPD with 64 bit data width.  I have tried the tranditional 32 bid width with the same results.
I have following error in the petalinux-build command:
Error: /data/fpga_designs/czeh/vision/HTG_image/TestBed_20_20190208/build/../components/plnx_workspace/device-tree/device-tree/pl.dtsi:77.34-48 Value out of range for 32-bit array element
Error: /data/fpga_designs/czeh/vision/HTG_image/TestBed_20_20190208/build/../components/plnx_workspace/device-tree/device-tree/pl.dtsi:81.26-40 Value out of range for 32-bit array element
Error: /data/fpga_designs/czeh/vision/HTG_image/TestBed_20_20190208/build/../components/plnx_workspace/device-tree/device-tree/pl.dtsi:82.26-40 Value out of range for 32-bit array element
FATAL ERROR: Syntax error parsing input tree
WARNING: /export/home/czeh/fpga_designs/vision/HTG_image/TestBed_20_20190208/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/run.do_compile.193529:1 exit 1 from 'dtc -I dts -O dtb -R 8 -p 0x1000 -b 0 -i /data/fpga_designs/czeh/vision/HTG_image/TestBed_20_20190208/build/../components/plnx_workspace/device-tree/device-tree -i /export/home/czeh/fpga_designs/vision/HTG_image/TestBed_20_20190208/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -i /export/home/czeh/fpga_designs/vision/HTG_image/TestBed_20_20190208/build/tmp/work-shared/plnx-zynqmp/kernel-source/arch/arm64/boot/dts/xilinx -i /export/home/czeh/fpga_designs/vision/HTG_image/TestBed_20_20190208/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -i /export/home/czeh/fpga_designs/vision/HTG_image/TestBed_20_20190208/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+f38738e568-r0 -o ${DTS_NAME}.dtb `basename ${DTS_FILE}`.pp'
ERROR: Function failed: do_compile (log file is located at /export/home/czeh/fpga_designs/vision/HTG_image/TestBed_20_20190208/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_compile.193529)
From the pl.dtsi file:
Line 77 - xlnx,rx-pause-da-mcast = <0x0180C2000001>;
Line 81 - xlnx,tx-da-gpp = <0x0180C2000001>;
Line 82 - xlnx,tx-da-ppp = <0x0180C2000001>;
I applied the patch associated with AR70285, but it does not help me get past this issue.
回复: Petalinux build failure - device-tree/pl.dtsi:77.34-48 Value out of range for 32-bit array element
czeh@ball
These errors are complaining that the DA and SA addresses from the IP core GUI are not 32-bit values.
As a workaround, you may modify pl.dtsi as below:
xlnx,tx-pause-da-mcast = /bits/ 64 <0x0180C2000001>;
xlnx,tx-da-gpp = /bits/ 64 <0x0180C2000001>;
xlnx,tx-da-ppp = /bits/ 64 <0x0180C2000001>;
Longley
czeh@ball
Longley
Observer czeh@ball
Re: Petalinux build failure - device-tree/pl.dtsi:77.34-48 Value out of range for 32-bit array element
Thank you for the suggestion.  I modified the script that was generated by the Xilinx tools.  The build does now complete but I am not sure of how this change impacts the functionality of the core.
Thank you for your help,
Chris
