cascadan
Petalinux build failure when changing Serial Settings
I'm starting a Petalinux development in ultra96-V2 using the "ultra96v2_oob_2018_3" example as reference. I could create the project from the BSP, build and test it successfully.  However, I tried to change the default serial output from "psu_uart_1"(default) to "axi_uart_16550_1", and so I started getting errors when trying to rebuild the project. Please, see attached the log.
I could build the device-tree alone (petalinux-build -b device-tree) and successfully tested the Linux terminal on "axi_uart_16550_1". But I could not build the u-boot alone (petalinux-build -c u-boot) due to this error. I also got similar error when trying to build the "rootfs" alone (petalinux-build -c rootfs).
Best,
André
File attached: <project_path>/ultra96v2_oob_2018_3/build/tmp/work/ultra96_zynqmp-xilinx-linux/u-boot-xlnx/v2018.01-xilinx-v2018.3+gitAUTOINC+d8fc4b3b70-r0/temp/log.do_compile.8571
0 Solutions
ksloatdesignlinx
 Can you attach your device tree snippet where you did this change?
Your actual error reported is:
/mnt/petalinuxhost_drive/workspace/ultra96v2_oob_2018_3/build/tmp/work/ultra96_zynqmp-xilinx-linux/u-boot-xlnx/v2018.01-xilinx-v2018.3+gitAUTOINC+d8fc4b3b70-r0/git/include/configs/platform-top.h:45:4: error: expected '}' before 'PSSERIAL0'
    PSSERIAL0 \
Ken Sloat - Embedded Software Engineer
https://www.designlinxhs.com
cascadan
Hi, thanks for the reply
I didn't actually touch the device tree. I just changed petalinux-config (Subsystem AUTO Hardware Settings -> Serial Settings). And it automatically produced a change in platform-auto.h, replacing the definition of PSSERIAL0 by ESERIAL0. This file also uses this definition on CONFIG_EXTRA_ENV_SETTINGS definition (see attached).
I also noticed the error you pointed. platform-top.h is not automatically changed, and PSSERIAL0 is no more being defined on platform-auto.h. It caused the error.
Solution: I just replaced PSSERIAL0 by ESERIAL0 in platform-top.h. With this workaround I could build the project successfully.
However, I still don't understand why CONFIG_EXTRA_ENV_SETTINGS is being defined in both files. It seems to cause inconsistencies, like the one described above.
cascadan
Unfortunately, for any reason, I can't attach my platform-top.h. I receive: "The attachment's platform-top.h content type (text/x-chdr) does not match its file extension and has been removed."
So I put it here
#include <configs/platform-auto.h>
/* FIXME Will go away soon */
#define CONFIG_SYS_I2C_MAX_HOPS 1
#define CONFIG_SYS_NUM_I2C_BUSES 9
#define CONFIG_SYS_I2C_BUSES { \
{0, {I2C_NULL_HOP} }, \
{0, {{I2C_MUX_PCA9548, 0x75, 0} } }, \
{0, {{I2C_MUX_PCA9548, 0x75, 1} } }, \
{0, {{I2C_MUX_PCA9548, 0x75, 2} } }, \
{0, {{I2C_MUX_PCA9548, 0x75, 3} } }, \
{0, {{I2C_MUX_PCA9548, 0x75, 4} } }, \
{0, {{I2C_MUX_PCA9548, 0x75, 5} } }, \
{0, {{I2C_MUX_PCA9548, 0x75, 6} } }, \
{0, {{I2C_MUX_PCA9548, 0x75, 7} } }, \
#define DFU_ALT_INFO_RAM \
"dfu_ram_info=" \
"setenv dfu_alt_info " \
"image.ub ram $netstart 0x1e00000\0" \
"dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \
"thor_ram=run dfu_ram_info && thordown 0 ram 0\0"
#define DFU_ALT_INFO_MMC \
"dfu_mmc_info=" \
"set dfu_alt_info " \
"${kernel_image} fat 0 1\\\\;" \
"dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0\0" \
"thor_mmc=run dfu_mmc_info && thordown 0 mmc 0\0"
#define CONFIG_USB_HOST_ETHER
#define CONFIG_USB_ETHER_ASIX
#define CONFIG_SYS_BOOTM_LEN 0xF000000
#define CONFIG_NR_DRAM_BANKS 3
#define DFU_ALT_INFO \
DFU_ALT_INFO_RAM
/* Extra U-Boot Env settings */
#define CONFIG_EXTRA_ENV_SETTINGS \
SERIAL_MULTI \
CONSOLE_ARG \
ESERIAL0 \
"nc=setenv stdout nc;setenv stdin nc;\0" \
"ethaddr=00:0a:35:00:22:01\0" \
"importbootenv=echo \"Importing environment from SD ...\"; " \
"env import -t ${loadbootenv_addr} $filesize\0" \
"loadbootenv=load mmc $sdbootdev:$partid ${loadbootenv_addr} ${bootenv}\0" \
"sd_uEnvtxt_existence_test=test -e mmc $sdbootdev:$partid /uEnv.txt\0" \
"uenvboot=" \
"if run sd_uEnvtxt_existence_test; then " \
"run loadbootenv; " \
"echo Loaded environment from ${bootenv}; " \
"run importbootenv; " \
"fi\0" \
"sdboot=echo boot Petalinux; run uenvboot ; mmcinfo && fatload mmc 0 ${netstart} ${kernel_img} && bootm \0" \
"autoload=no\0" \
"clobstart=0x10000000\0" \
"netstart=0x10000000\0" \
"dtbnetstart=0x11800000\0" \
"loadaddr=0x10000000\0" \
"boot_img=BOOT.BIN\0" \
"load_boot=tftpboot ${clobstart} ${boot_img}\0" \
"update_boot=setenv img boot; setenv psize ${bootsize}; setenv installcmd \"install_boot\"; run load_boot ${installcmd}; setenv img; setenv psize; setenv installcmd\0" \
"install_boot=mmcinfo && fatwrite mmc 0 ${clobstart} ${boot_img} ${filesize}\0" \
"bootenvsize=0x40000\0" \
"bootenvstart=0x1360000\0" \
"eraseenv=sf probe 0 && sf erase ${bootenvstart} ${bootenvsize}\0" \
"jffs2_img=rootfs.jffs2\0" \
"load_jffs2=tftpboot ${clobstart} ${jffs2_img}\0" \
"update_jffs2=setenv img jffs2; setenv psize ${jffs2size}; setenv installcmd \"install_jffs2\"; run load_jffs2 test_img; setenv img; setenv psize; setenv installcmd\0" \
"sd_update_jffs2=echo Updating jffs2 from SD; mmcinfo && fatload mmc 0:1 ${clobstart} ${jffs2_img} && run install_jffs2\0" \
"install_jffs2=sf probe 0 && sf erase ${jffs2start} ${jffs2size} && " \
"sf write ${clobstart} ${jffs2start} ${filesize}\0" \
"kernel_img=image.ub\0" \
"load_kernel=tftpboot ${clobstart} ${kernel_img}\0" \
"update_kernel=setenv img kernel; setenv psize ${kernelsize}; setenv installcmd \"install_kernel\"; run load_kernel ${installcmd}; setenv img; setenv psize; setenv installcmd\0" \
"install_kernel=mmcinfo && fatwrite mmc 0 ${clobstart} ${kernel_img} ${filesize}\0" \
"cp_kernel2ram=mmcinfo && fatload mmc 0 ${netstart} ${kernel_img}\0" \
"dtb_img=system.dtb\0" \
"load_dtb=tftpboot ${clobstart} ${dtb_img}\0" \
"update_dtb=setenv img dtb; setenv psize ${dtbsize}; setenv installcmd \"install_dtb\"; run load_dtb test_img; setenv img; setenv psize; setenv installcmd\0" \
"sd_update_dtb=echo Updating dtb from SD; mmcinfo && fatload mmc 0:1 ${clobstart} ${dtb_img} && run install_dtb\0" \
"fault=echo ${img} image size is greater than allocated place - partition ${img} is NOT UPDATED\0" \
"test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${img} is NOT UPDATED; fi\0" \
"test_img=setenv var \"if test ${filesize} -gt ${psize}\\; then run fault\\; else run ${installcmd}\\; fi\"; run var; setenv var\0" \
"netboot=tftpboot ${netstart} ${kernel_img} && bootm\0" \
"default_bootcmd=run cp_kernel2ram && bootm ${netstart}\0" \
