Petalinux-build --jtag in VirtualBox
I'm reading through this document UG1209.
So far I managed to boot a pre-built Petalinux image via SD card on my EK-ZCU102-G,
but now I would like to load my own compiled version via JTAG.
I'm using Ubuntu 16.04 in a VirtualBox on Windows 10.
The JTAG interface is connected to hw_server via Lab Solutions and I can connect to it via xsdb and Vivado Hardware Manager.
When I run petalinux-boot --jtag --prebuilt 2 it tells me it cannot find a supported FPGA device.
It tried to recmmendations from AR 66943,
but since I only have 1 JTAG interface I don't fully understand where it goes wrong.
How can I make the petalinux-boot --jtag command point to the IP and port of my host machine? (to find the FPGA device)
Could you please help?
Best Regards,
Kristof
Instructor
Instructor
kli@melexis.com
I'm not sure this is your issue, but did you enable the USB ports to pass through to the VirtualBox? (As I remember, that was not the default state to do so.)
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
I was under the assumption that my Ubuntu Virtualbox will connect to hw_server running on Windows 10 via ethernet.
connect -host 192.168.56.1 -port 5151 works perfectly to program other example code,
problem is that with petalinux --jtag I'm looking for a way to tell it to connect to that hw_server via ethernet. :)
