Visitor shmadoge
Petalinux build on u-boot with "undefined reference to `ioremap_nocache'"
I'm trying to build linux distro for custom board with zynq and after configuring sw project i'm getting this error:
drivers/net/built-in.o: In function `emaclite_ofdata_to_platdata':
| /home/e_rush/work/test_boot/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/u-boot-xlnx/v2018.01-xilinx-v2018.2+gitAUTOINC+21812b5fd3-r0/git/drivers/net/xilinx_emaclite.c:602: undefined reference to `ioremap_nocache'
Manually changing line in xilinx_emaclite.c from:
emaclite->regs = (struct emaclite_regs *)ioremap_nocache(pdata->iobase,
0x10000);
to:
emaclite->regs = (struct emaclite_regs *)pdata->iobase;
lets me build but I don't think that is valid solution.
Do you guys have any idea how to prevent this?
Vivado and Petalinux version is 2018.2.
Re: Petalinux build on u-boot with "undefined reference to `ioremap_nocache'"
It looks to me that uboot emaclite driver has not been updated being a legacy IP. I would suggest to disable the uboot driver and keep linux emaclite driver enabled. You can disable uboot driver using this step: petalinux-config -c u-boot -> Device  drivers -> Network device support -> emaclite
May I what changes have you done with ethernet in your design?
Visitor shmadoge
I don't think there is a problem with design(here it is https://drive.google.com/open?id=15GvklzztV2NUtktcJscMqIqp4rdOLh-i ), since I checked source code of xilinx u-boot and there is no function ioremap_nocache (which is called from emaclight driver) in arm/asm/io, it was deleted couple of years ago.
https://github.com/Xilinx/u-boot-xlnx/blob/master/drivers/net/xilinx_emaclite.c
https://github.com/Xilinx/u-boot-xlnx/blob/master/arch/arm/include/asm/io.h
Is it possible to share your HDF?
Best Regards
Shabbir
Visitor shmadoge
I seen this issue too. Seems like a bug. I patched driver same as you and has been working fine for me
