Observer adithyab
Petalinux build takes too long
I have started using petalinux (2018.2) for generation of linux images.
I thing I find annoying is that the build is very slow. Even if I change just one line in kernel, build easily takes 15~20 minutes. Even something like 'petalinux-build -c kernel' does not seem to make any difference.
Is there any way to speed up the build?
Re: Petalinux build takes too long
Hi @adithyab
Please refer to UG1144 guide below (Page 33) which explains Build optimization techniques
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1144-petalinux-tools-reference-guide.pdf
Best Regards
Shabbir
Observer adithyab
@shabbirk
I have removed the fsbl and pmu as I don't need it to build every time.
I did see a parallel thread tab in yocto settings which was blank. I have set both the number of threads and parallel make to 4 (number of cpu cores). I don't see that this is mentioned in the user guide.
local Sstate looks like interesting option. I will need some time to download and set it up.
See Building Ignoring Dependencies at p35 of ug1144
petalinux-build -b recipe ignore depencies of the recipe
You can set local sstate location from Yocto Setting using petalinux-config
Newbie evelyn233
