09-03-2018 04:42 AM
Hey everyone, i got a situation here. I create a new petalinux project by this command
petalinux-create --type project --template zynq --name KM-3000_PetaLinux
and then i wanted to go for this command. However, i got the same error every time i have tried to run this.
petalinux-config --get-hw-description -p /home/selcuk/Projects/PetaLinux/KM-3000_PetaLinux
and this is the log message of error.
[INFO] generating Kconfig for project rlwrap: warning: your $TERM is 'xterm-256color' but rlwrap couldn't find it in the terminfo database. Expect some problems.: Inappropriate ioctl for device package require xsdb FAILED: can't find package xsdbERROR: Failed to generate /home/sukru/FPGA/KM-3000_Petalinux/build/misc/config/Kconfig.syshw ERROR: Failed to Kconfig project ERROR: Failed to build project
I have also created the project and i tried to run another petalinux command, for example, petalinux-config or petalinux-build but whenever i run something begins with petalinux command, except petalinux-create, i get error log which is above. Can anyone give me an explanation what causes that error?
09-03-2018 11:08 PM
I found the problem! Petalinux should have installed on home directory in Linux. Thats why i got those errors.
09-03-2018 10:13 PM
Hi @sya0,
You need to run the configuration command from petalinux project folder.
Should not run from outside of the project.
Run config command like below:
petalinux-config --get-hw-description=/aravind_working_dir/tmp/blockbox/customer_hdf/2017.4_hdf/
Thanks & regards
Aravind
09-03-2018 10:52 PM
I got still same error
INFO: Getting hardware description... INFO: Rename system_wrapper.hdf to system.hdf [INFO] generating Kconfig for project ERROR: Failed to generate /home/sukru/FPGA/KM-3000_Petalinux/build/misc/config/Kconfig.syshw ERROR: Failed to Kconfig project ERROR: Failed to generate System hardware Kconfig file.
09-03-2018 11:08 PM
04-24-2020 09:23 AM - edited 04-24-2020 09:24 AM
