icstars
Petalinux compilation issues
hello everyone
i'm trying to build petalinux boot files from zynq template and it builds succesfully but uboot seems to ignore settings from petalinux-config (for example it tries to load environment from spi flash, which i don't even have in my hardware project)
i am quite new to petalinux sdk so i believed that selecting uboot auto config in autoconfig settings but with this option selected project fails to compile with oe_runmake error
here is build log of projected with selected u-boot autoconfig
could anyone help me with this issue?
stephenm
This looks like your boot log. Can you place the boot.scr, BOOT.BIN and the image.ub onto your SD card and try again?
icstars
already did it
i tried formatting my card in fat32 and placing all the three files there
then i tried dividing my sd card into two partitions - fat32 and ext4 to place rootfs on sd
nothing in the boot log changes at all
stephenm
icstars
yes, i can
it seems to work at first but then stops with message: id "ps0" is respawning too fast: disabled for 5 minutes
icstars
so, i have switched from 2020.1 to 2019.2
now i can succesfully compile my project with u-boot autoconfig, my board boots and seems to work fine
still don't know what was the problem
