leith
Petalinux cron??
Much to my surprise, Petalinx (at least v17.4) does not include any sort of cron daemon.
I would imagine the easiest/most appropriate way to get his is to enable busybox cron.   The config files don't have this as an option.
I guess this means I need to replace the Petalinux busybox with a more robust version.   What's the easiest way to do this?
Thanks for any help.
xilinxacct
Professor
Professor
@leith
A poor man's cron, could be implemented with a 'sleep' in a script. sleep should be availble in busybox.
Hope that helps
If so, mark as solution accepted to close the issue. Kudos also welcomed. :-)
leith
Cron, as well as some other busybox feature are "there" but just not turned on.   Cron can be enabled in the build with the following:
add file file project-spec/meta-plnx-generated/recipes-core/busybox/files/crond.cfg
  CONFIG_CROND=y
add file project-spec/meta-plnx-generated/recipes-core/busybox/busybox_1.%.bbappend
  FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
  SRC_URI_append = "\
      file://crond.cfg "
Cron seems like such a basic, well known Unix feature.   Can't figure out why Xilinx doesn't make it an easy to select feature in config??
vanmierlo
Mentor
Mentor
The above is almost right. You should not place and modify files in project-spec/meta-plnx-generated/ but instead you should use project-spec/meta-user/ . Otherwise they get overwritten everytime you reconfigure.
