Petalinux custome rootfs
I've been using petalinux for a while now and I really like it, specially when it comes to creating applications and modules, but the rootfs seams a bit... minimalist.
As far as I know you can point using petalinux to a local kernel source and u-Boot source, can you do the same with rootfs? I'd like to download a custom rootfs and then using petalinux-build leave it up to him to build/add my apps and modules to the final version of the rootfs.
Ciprian
Re: Petalinux custome rootfs
Hi Ciprian !
Not sure if this helps, but we have a "root" directory that will be overlayed on top of the petalinux rootfs. Comes in real handy.
copy_rootfs() {
cp -a -r ${SRC_ZYNQ}/rootfs/testproject/* ${IMAGE_ROOTFS};
[Do other things like removing files you dont need here]
IMAGE_PREPROCESS_COMMAND += "copy_rootfs; "
Cheers !
/Otto
Hi @ottob,
Not sure if that's what I'm looking for, but i'd like to try. Where do I add or change this code?
-Ciprian
Add it to
meta-user/recipes-core/images/petalinux-user-image.bbappend
You'll need to update the paths though
Observer borsec
You can just put another on the sd card. I can give you a rootfs image, but just in few days when I get back home.
