Petalinux driver/module for custom AXI-Lite IP
I am getting my embedded linux system up and running on a ZCU102 board. I used petalinux with the reference BSP and got my linux up and running. I added an echo server application. It works.
I then went back to Vivado, added an custom peripheral for which the CPU interface is an AXI4-Lite Slave. Connected, generated a bit stream, exported the HW.
I go back to petalinux, rerun petalinux-config --get-hw-description..
Now:
in pl.dtsi I see my peripheral...Great
in <proj-dir>project-spec/hw-description/drivers/ there is the driver code that Vivado created for my peripheral.
I didn't modify the driver at all, so it basically consists of calls to Xil_In32 and Xil_Out32
I don't know exactly what I need to do right now. I find my self wanting to just include the header in my application, but when I tried that, compilation of my application failed, because it couldn't find the header. But, even if I could direct it to the header, I feel like that should fail because to talk to hardware I need to make system calls via exposed functions in a kernel module.
But if that is the case, then what is the point of the driver that Vivado compiles and Petalinux imports? Do I need to adapt the Driver into a module? I briefly read about using the Userspace IO module, but that seems to not use the Xil_In32 and Xil_Out32 calls.
I guess what I'm trying to figure out is, I added a custom peripheral to my hardware, with an AXI4-Lite Slave interface. I then imported said hardware into my petalinux project. What do I need to do now?
Does petalinux automagically create and include the appropriate ko module?
Do I need to create a ko module? from Scratch? or Start with the driver that was imported? or is the driver only really useful for bare-metal use cases?
Re: Petalinux driver/module for custom AXI-Lite IP
The tools will create a Baremetal driver that uses the API that you mentioned in the standalone BSP and is not applicable in Linux
If you want to create a driver, I would use the UIO driver as a stating point.
http://www.wiki.xilinx.com/Testing+UIO+with+Interrupt+on+Zynq+Ultrascale
thanks stephenm,
I have it working with linux seeing my IP as a UIO device, and then I use mmap to get access to the registers. I'm going to have to think about how I want to use this setup, and my first thought is, do any of the AXI IP have prebuilt kernel modules/drivers?
I'm thinking about how my design in the PL will interface to the PS, and I will likely have an AXI Stream Fifo with the PS on one side and custom logic on the other side.
So, I've made some headway answering my own question.
http://www.wiki.xilinx.com/Linux%20Drivers
It looks like what I'm looking for is likely one of the axi_dma drivers.
Also,
the below post appears to show usage/control of the axi_dma block using mm'ed IO.
https://lauri.xn--vsandi-pxa.com/hdl/zynq/xilinx-dma.html
