mashman
Petalinux error after moving project to another directory
Petalinux 2020, I have been building with no problem but I had to move the project directory. After moving I had to add the PetaLinux files to version control so I followed the instructions in UG1144 and cleaned the project using petalinux-build -x mrproper.
Now when I run pealinux-build I am getting errors.
Here is part of the error. I've attached the full log file. What do I need to do to recover and build my project?
EBUG: Executing python function do_populate_sysroot_setscene
DEBUG: Executing shell function sstate_unpack_package
sysroot-destdir/
sysroot-destdir/sysroot-providers/
sysroot-destdir/sysroot-providers/glibc
sysroot-destdir/sysroot-providers/virtual_libiconv
sysroot-destdir/sysroot-providers/virtual_libc
sysroot-destdir/lib/
sysroot-destdir/lib/libnss_db-2.30.so
sysroot-destdir/lib/libthread_db-1.0.so
sysroot-destdir/lib/libc-2.30.so
sysroot-destdir/lib/libnss_dns-2.30.so
sysroot-destdir/lib/ld-2.30.so
sysroot-destdir/lib/libresolv-2.30.so
sysroot-destdir/lib/libBrokenLocale.so.1
sysroot-destdir/lib/libanl-2.30.so
sysroot-destdir/lib/libresolv.so.2
sysroot-destdir/lib/libmemusage.so
sysroot-destdir/lib/libSegFault.so
sysroot-destdir/lib/libanl.so.1
sysroot-destdir/lib/libnss_compat.so.2
sysroot-destdir/lib/libm.so.6
sysroot-destdir/lib/libnss_compat-2.30.so
sysroot-destdir/lib/libpthread.so.0
sysroot-destdir/lib/librt-2.30.so
sysroot-destdir/lib/libnsl-2.30.so
sysroot-destdir/lib/libBrokenLocale-2.30.so
sysroot-destdir/lib/librt.so.1
sysroot-destdir/lib/libutil.so.1
sysroot-destdir/lib/libdl-2.30.so
sysroot-destdir/lib/libnsl.so.1
sysroot-destdir/lib/libutil-2.30.so
sysroot-destdir/lib/libnss_db.so.2
sysroot-destdir/lib/libpthread-2.30.so
gzip: stdin: unexpected end of file
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
WARNING: exit code 2 from a shell command.
ERROR: Error executing a python function in exec_python_func() autogenerated:
VM snapshots are a great thing
I normally don't move PL projects to another folder, why should you? Is just a place where it leaves...
Whenever I had to, I first do a -mrproper clean build, then move the remaining things (allegedly the bare minimum sources).
Petalinux is complex and goes beyond Xilinx hands. It may depend on your settings and add-ons that there is some path hard-coded.
Just a reminder... Xilinx really hates paths with spaces, you don't have that, do you?
mashman
Any suggestions from Xilinx on this??
aravindb
HI @mashman
It is not recommended  to move the petalinux project from one directory to other directory & build.
As all the files/directories will be stored with absolute paths when creating the project. you will see build errors.
if you rename the project directory you need to rum "petalinux-build -x mrproper" and need to build again this will work some times.
Thanks & regards
Aravind
mrproper has recovered from many weird situations for me
mashman
I ran petalinux-build -f -x mrproper, and then tried to build with petalinux-build and it failed again. What is the right way to rename a project folder for a PetaLinux project? Do I need to start from scratch?
first, will the project, as is, build in the original directory?
mashman
archangel-lightworks
Fair question, maybe something went wrong with the actual move. I'm doing this on a VM and I have a checkpoint from before the move, I'm going to restore that and try again. What is the proper way to move a PetaLinux project? I need to move it so I can add it to a Git repository and really don't want to start over.
I wonder if there is a tool kind of 'package project' 'export project' etc. in Petalinux.
Having projects hard-tied to folders make team- and version controlled- work almost impossible.
mashman
Yes, this is what I ended up doing. Do a -mrproper first, then move (then I did it again which is not necessary, but I did it anyway). Things seem to be good now. And I agree with your other post, the tool does not lend itself to team environments so it would be nice to be able to export/import a project so it could be moved around. But for now we will have to make sure the paths are always the same. Thanks!
