Petalinux fails: No rule to make target clean
I've run across a problem where when building my application in petalinux 2017.3, via the command line call:
petalinux-build -c myapplication
or
petalinux-build -c myapplication -x compile
the process errors out, with:
ERROR: myapplication-1.0-r0 do_configure: oe_runmake failed
...(more stuff)
Note: make clean
ERROR:oe_runmake failed
make: ** No rule to make target 'clean'. Stop.
I'm using the petalinux generated bbappend file, as well as the petalinux generated Makefile. It is worth noting that the Makefile has no "clean" target, and if I manually add one, I can make this problem go away. BUT, it concerns me that I'm having to manually add the "clean" target, and I'd like a better solution than "This is just petalinux being sloppy, fix it yourself."
Has anyone else had this problem or does anyone have insight into why this might occur?
Tags (2)
Recipe looks good.
Can you run below commands and post the output.
$ petalinux-build -c myapplication -x cleanall
#For more details on recipes tasks run this
$ petalinux-build -c myapplication -x listtasks
Sandeep
Hi @mckinjo4,
Can you post the content on myapplication.bb and Makefile file?
Sandeep
the bbappend file:
# This file is the tcp-echo-server recipe.
SUMMARY = "Simple tcp-echo-server application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://tcp-echo-server.c \
	   file://Makefile \
S = "${WORKDIR}"
do_compile() {
	     oe_runmake
do_install() {
	     install -d ${D}${bindir}
	     install -m 0755 tcp-echo-server ${D}${bindir}
the makefile:
APP = tcp-echo-server
# Add any other object files to this list below
APP_OBJS = tcp-echo-server.o
all: build
build: $(APP)
$(APP): $(APP_OBJS)
	$(CC) $(LDFLAGS) -o $@ $(APP_OBJS) $(LDLIBS)
Recipe looks good.
Sandeep
OK,
So When I run:
everything works. I haven't since been able to recreate the situation where I it won't build without a manual "clean" target, but in trying to do so, I've been able to see something else. If appears that petalinux in some cases misreports the error. In the below sequence of commands, I induce a syntax error (specifically by removing a ; at the end of a line, or by erasing the # infront of a define statement.) The error that is reported is "No rule to make clean":
[mckinneyj@inf-lg2-wks58 tcp-echo-server]$ petalinux-build -c tcp-echo-server -x cleanall
[INFO] building tcp-echo-server
[INFO] sourcing bitbake
INFO: bitbake tcp-echo-server -c cleanall
WARNING: Host distribution "CentOS-7.4.1708" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |###############################################################################################################################################| Time: 0:00:00
Loaded 3271 entries from dependency cache.
Parsing recipes: 100% |#############################################################################################################################################| Time: 0:00:01
Parsing of 2481 .bb files complete (2447 cached, 34 parsed). 3274 targets, 225 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |##########################################################################################################################################| Time: 0:00:00
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 3 tasks of which 0 didn't need to be rerun and all succeeded.
Summary: There was 1 WARNING message shown.
[INFO] successfully built tcp-echo-server
webtalk failed:PetaLinux statistics:extra lines detected:notsent_nofile!
webtalk failed:Failed to get PetaLinux usage statistics!
Checking sstate mirror object availability: 100% |##################################################################################################################| Time: 0:00:00
NOTE: Executing SetScene Tasks
NOTE: Tasks Summary: Attempted 568 tasks of which 553 didn't need to be rerun and all succeeded.
INFO: Copying Images from deploy to images
NOTE: Successfully copied built images to tftp dir:  /var/lib/tftpboot
[mckinneyj@inf-lg2-wks58 tcp-echo-server]$ petalinux-build -c tcp-echo-server -x compile
INFO: bitbake tcp-echo-server -c compile
NOTE: Tasks Summary: Attempted 226 tasks of which 221 didn't need to be rerun and all succeeded.
CAUSE_SYNTAX_ERROR_IN_FILE
ERROR: tcp-echo-server-1.0-r0 do_configure: oe_runmake failed
ERROR: tcp-echo-server-1.0-r0 do_configure: Function failed: do_configure (log file is located at /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/log.do_configure.64969)
ERROR: Logfile of failure stored in: /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/log.do_configure.64969
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function do_configure
| NOTE: make clean
| ERROR: oe_runmake failed
| make: *** No rule to make target 'clean'.  Stop.
| WARNING: /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/run.do_configure.64969:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_configure (log file is located at /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/log.do_configure.64969)
ERROR: Task (/data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/project-spec/meta-user/recipes-apps/tcp-echo-server/tcp-echo-server.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 225 tasks of which 221 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build tcp-echo-server
FIXED SYNTAX ERROR IN FILE
NOTE: Tasks Summary: Attempted 226 tasks of which 226 didn't need to be rerun and all succeeded.
ERROR: tcp-echo-server-1.0-r0 do_configure: Function failed: do_configure (log file is located at /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/log.do_configure.67882)
ERROR: Logfile of failure stored in: /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/log.do_configure.67882
Log data follows:
| NOTE: make clean
| WARNING: /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/run.do_configure.67882:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_configure (log file is located at /data/mckinneyj/fpga_projects/fpga_irad/xapp1305-ps-pl-based-ethernet-solution-2017.3/software/stardust/build/tmp/work/aarch64-xilinx-linux/tcp-echo-server/1.0-r0/temp/log.do_configure.67882)
FIXED SYNTAX ERROR
