bsarbb
Petalinux gstreamer Support
I am trying to enable gstreamer over petalinux development environment.
For this purpose, I simply enable packagegroup-petalinux-gstreamer configuration option with using petalinux-config command.
Then I searched gstreamer related recipes in ${PRJ_DIR}/components/yocto/layers directory. I found two gstreamer recipe.
  1. gstreamer1.0_%.bbappend
    This file is in meta-petalinux layer.
  2. gstreamer1.0_1.16.1.bb
    This file is in core layer.
Both of these layers are added to the "BBLAYERS" and both layer's priority (spesified with BBFILE_PRIORITY_xx) are same (5).
I made following changes to understand the recipe lookup process of bitbake.
  1. I corrupted valid github URL in  gstreamer1.0_%.bbappend.
    Linux system build process finished with error in this trial.
  2. I corrected the github URL then corrupted valid source code address in  gstreamer1.0_1.16.1.bb.
    This time build process finished successfully.
    From this, I understood that bitbake somehow decided to use use gstreamer1.0_%.bbappend recipe.
So How bitbake decide to use usegstreamer1.0_%.bbappend recipe ? What is the selection criteria ?
Also,
  1. I increased the priority of core layer from 5 to 6 and corrupt and again corrupted the source code address spesified in gstreamer1.0_1.16.1.bb.
    This time, I supposed to encounter with an error, but build process finished successfully again.
So,
Why this priority increment operation does not take effect ?
hokim
The priorities between bb and bbappend  are irrelevant
bbappend always appends or overlays to bb
The priority among bbs and that among bbappends are separate
bbappends are appended in order of BBFILE_PRIORITY defined in each layer’s layer.conf file e.g. a bbappend in layer with BBFILE_PRIORITY = 5
will be appended before bbappend from another layer with BBFILE_PRIORIY = 6
