madhu.mami60
Petalinux .hdf file updation
I have generated bitstream for my board. And i have exported my Hardware design. I copied my .hdf file to Linux machine (to hdf_dir directory).
Then i built petalinux using the .hdf.
$: petalinux-config --get-hw-description=./hdf_dir
Suppose, if i do some modification in vivado. Then i exported new .hdf. Then how do update my petalinux project with new hdf file?
1) Is it just sufficient to replace my hdf file
     If yes, where do i replace?
     in "hdf_dir" directory or "peta_project/project-spec/hw-description"
2) Is there any petalinux command to update?
Madhu
florentw
Hi @madhu.mami60,
When you export a new hdf from vivado you should re-do:
Petalinux should then detect if there is a change in the hw.
Kind Regards,
Florent
Florent
madhu.mami60
Hi @florentw
Yeah, I did the same.. Then i rebuild the whole thing, u-boot.elf size increses from 2.1MB to 11.9MB. And linux.ub also increases from ~10MB to ~20MB.
The linux image may increase due to added drivers/features...
But, Why this much increment in u-boot? What could the things is wrong?
Madhu
