Petalinux image not booting properly
I have made a petalinux project to run on the Ultrascale board. I have configured the proper settings to enable openAMP in the image. I am booting the image from sd card but the it never boots properly. Even if it does reach the part where it asks for the login and password prompt, it stops taking keyboard after a few seconds. I am posting the boot log of the board. Please advise me as how to remove this problem.
U-Boot 2017.01 (Jul 26 2018 - 12:35:25 +0500) Xilinx ZynqMP ZCU102 revB
I2C:   ready
DRAM:  2 GiB
ERROR: usb dr_mode not found
at /home/afzal/Mubashira/Petalinux_prj/dma_prj1/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.4+gitAUTOINC+5fa7d2ed06-r0/git/drivers/usb/common/common.c:32/usb_get_dr_mode()
EL Level:       EL2
Chip ID:        xczu3eg
MMC:   sdhci@ff160000: 0 (eMMC), sdhci@ff170000: 1 (SD)
zynqmp_qspi_ofdata_to_platdata: CLK 124999999
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
In:    serial
Out:   serial
Err:   serial
Net:   ZYNQ GEM: ff0e0000, phyaddr 9, interface rgmii-id
Warning: ethernet@ff0e0000 (eth0) using random MAC address - 22:73:e7:ce:e0:ed
eth0: ethernet@ff0e0000
U-BOOT for UltraZed ZynqMP
switch to partitions #0, OK
mmc1 is current device
reading ultrazed_base.bit
** Unable to read file ultrazed_base.bit **
Wrong parameters for FPGA request
fpga - loadable FPGA image support
Usage:
fpga [operation type] [device number] [image address] [image size]
fpga operations:
  dump  [dev] [address] [size]  Load device to memory buffer
  info  [dev]                   list known device information
  load  [dev] [address] [size]  Load device from memory buffer
  loadp [dev] [address] [size]  Load device from memory buffer with partial bitstream
  loadb [dev] [address] [size]  Load device from bitstream buffer (Xilinx only)
  loadbp        [dev] [address] [size]  Load device from bitstream buffer with partial bitstream(Xilinx only)
Load encrypted bitstream (Xilinx only)
  loads [dev] [address] [size] [key/sigaddr:size]
        [IV/PPKaddr:size] [secureimgtype]
Loads the secure bistreams(authenticated/encrypted)image of
[size] from [address] using key/signature(key for encrypted
bitstreams and signature for authenticated bitstreams) from
address whose :size and IV/PPK at address with size. The secure
image type specifies whether it is authenticated/encrypted
(0-enc, 1-auth) type of bitstream
reading system.dtb
33354 bytes read in 15 ms (2.1 MiB/s)
reading Image
18883072 bytes read in 1373 ms (13.1 MiB/s)
## Flattened Device Tree blob at 11800000
   Booting using the fdt blob at 0x11800000
   Loading Device Tree to 0000000007ff4000, end 0000000007fff249 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.0-xilinx-v2017.4 (afzal@afzal-VirtualBox) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #4 SMP Thu Jul 26 13:22:41 PKT 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc06ff75000 s48152 r8192 d29672 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513024
[    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk1p2 rw earlyprintk rootfstype=ext4 rootwait clk_ignore_unused
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1767408K/2080768K available (9084K kernel code, 584K rwdata, 2844K rodata, 5888K init, 397K bss, 51216K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008960000   (  9088 KB)
[    0.000000]     .rodata : 0xffffff8008960000 - 0xffffff8008c30000   (  2880 KB)
[    0.000000]       .init : 0xffffff8008c30000 - 0xffffff80091f0000   (  5888 KB)
[    0.000000]       .data : 0xffffff80091f0000 - 0xffffff8009282200   (   585 KB)
[    0.000000]        .bss : 0xffffff8009282200 - 0xffffff80092e5634   (   398 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01c00000   (    28 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.000277] Console: colour dummy device 80x25
[    0.000298] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.000307] pid_max: default: 32768 minimum: 301
[    0.000421] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000428] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.001080] ASID allocator initialised with 65536 entries
[    0.001642] zynqmp_plat_init Power management API v0.3
[    0.001727] EFI services will not be available.
[    0.162762] Detected VIPT I-cache on CPU1
[    0.162792] CPU1: Booted secondary processor [410fd034]
[    0.273998] Detected VIPT I-cache on CPU2
[    0.274017] CPU2: Booted secondary processor [410fd034]
[    0.399192] Detected VIPT I-cache on CPU3
[    0.399210] CPU3: Booted secondary processor [410fd034]
[    0.399249] Brought up 4 CPUs
[    0.399264] SMP: Total of 4 processors activated.
[    0.399270] CPU features: detected feature: 32-bit EL0 Support
[    0.399278] CPU: All CPU(s) started at EL2
[    0.399293] alternatives: patching kernel code
[    0.399859] devtmpfs: initialized
[    0.404701] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.410899] xor: measuring software checksum speed
[    0.448318]    8regs     :  2111.000 MB/sec
[    0.488346]    8regs_prefetch:  1881.000 MB/sec
[    0.528376]    32regs    :  2594.000 MB/sec
[    0.568407]    32regs_prefetch:  2181.000 MB/sec
[    0.568411] xor: using function: 32regs (2594.000 MB/sec)
[    0.568512] pinctrl core: initialized pinctrl subsystem
[    0.569233] NET: Registered protocol family 16
[    0.587044] cpuidle: using governor menu
[    0.587277] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.587495] vdso: 2 pages (1 code @ ffffff8008967000, 1 data @ ffffff80091f4000)
[    0.587506] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.588130] DMA: preallocated 256 KiB pool for atomic allocations
[    0.598811] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.599676] ARM CCI_400_r1 PMU driver probed
[    0.603110] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.623367] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.688720] raid6: int64x1  gen()   374 MB/s
[    0.756660] raid6: int64x1  xor()   408 MB/s
[    0.824686] raid6: int64x2  gen()   622 MB/s
[    0.892733] raid6: int64x2  xor()   552 MB/s
[    0.960799] raid6: int64x4  gen()   906 MB/s
[    1.028812] raid6: int64x4  xor()   679 MB/s
[    1.096887] raid6: int64x8  gen()  1053 MB/s
[    1.164925] raid6: int64x8  xor()   685 MB/s
[    1.232985] raid6: neonx1   gen()   666 MB/s
[    1.300992] raid6: neonx1   xor()   698 MB/s
[    1.369069] raid6: neonx2   gen()  1076 MB/s
[    1.437105] raid6: neonx2   xor()   951 MB/s
[    1.505173] raid6: neonx4   gen()  1384 MB/s
[    1.573211] raid6: neonx4   xor()  1085 MB/s
[    1.641256] raid6: neonx8   gen()  1457 MB/s
[    1.709298] raid6: neonx8   xor()  1120 MB/s
[    1.709303] raid6: using algorithm neonx8 gen() 1457 MB/s
[    1.709306] raid6: .... xor() 1120 MB/s, rmw enabled
[    1.709310] raid6: using intx1 recovery algorithm
[    1.710268] SCSI subsystem initialized
[    1.710488] usbcore: registered new interface driver usbfs
[    1.710530] usbcore: registered new interface driver hub
[    1.710571] usbcore: registered new device driver usb
[    1.710643] media: Linux media interface: v0.10
[    1.710677] Linux video capture interface: v2.00
[    1.710706] pps_core: LinuxPPS API ver. 1 registered
[    1.710711] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.710727] PTP clock support registered
[    1.710754] EDAC MC: Ver: 3.0.0
[    1.711067] FPGA manager framework
[    1.711215] fpga-region fpga-full: FPGA Region probed
[    1.711315] Advanced Linux Sound Architecture Driver Initialized.
[    1.711659] Bluetooth: Core ver 2.22
[    1.711683] NET: Registered protocol family 31
[    1.711687] Bluetooth: HCI device and connection manager initialized
[    1.711697] Bluetooth: HCI socket layer initialized
[    1.711705] Bluetooth: L2CAP socket layer initialized
[    1.711728] Bluetooth: SCO socket layer initialized
[    1.712398] clocksource: Switched to clocksource arch_sys_counter
[    1.712495] VFS: Disk quotas dquot_6.6.0
[    1.712539] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.717651] NET: Registered protocol family 2
[    1.718045] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.718162] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.718443] TCP: Hash tables configured (established 16384 bind 16384)
[    1.718514] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.718559] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.718708] NET: Registered protocol family 1
[    1.718943] RPC: Registered named UNIX socket transport module.
[    1.718948] RPC: Registered udp transport module.
[    1.718952] RPC: Registered tcp transport module.
[    1.718956] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.944557] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.945433] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    1.945515] audit: initializing netlink subsys (disabled)
[    1.945554] audit: type=2000 audit(1.940:1): initialized
[    1.946144] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.946870] NFS: Registering the id_resolver key type
[    1.946890] Key type id_resolver registered
[    1.946894] Key type id_legacy registered
[    1.946904] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.946924] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.955403] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.955417] io scheduler noop registered
[    1.955421] io scheduler deadline registered
[    1.955433] io scheduler cfq registered (default)
[    1.956766] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.956958] xilinx-vdma 90000000.dma: unable to request IRQ 0
[    1.956966] xilinx-vdma 90000000.dma: dma_async_device_register: device has no channels!
[    1.956974] xilinx-vdma 90000000.dma: Xilinx AXI DMA Engine Driver Probed!!
[    1.957171] Write failed gate address:1000f02
[    1.957269] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.957407] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.957540] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.957677] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.957810] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.957945] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.958082] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.958219] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.958426] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.958564] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.958699] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.958836] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.958972] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.959108] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.959242] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.959382] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.959565] zynqmp_pm firmware: Power management API v0.3
[    1.959674] xenfs: not registering filesystem on non-xen platform
[    1.991766] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.993007] [drm] Initialized
[    1.993441] [drm] load() is defered & will be called again
[    1.993979] xilinx-drm-dp-sub fd4aa000.dp_sub: Xilinx DisplayPort Subsystem is probed
[    1.994163] Unable to detect cache hierarchy from DT for CPU 0
[    1.999709] brd: module loaded
[    2.003173] loop: module loaded
[    2.004082] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    2.004093] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.005097] scsi host0: ahci-ceva
[    2.005337] scsi host1: ahci-ceva
[    2.005489] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[    2.005496] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[    2.005658] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.006562] m25p80 spi0.0: found n25q256a, expected n25q512a
[    2.006688] m25p80 spi0.0: n25q256a (65536 Kbytes)
[    2.006707] 3 ofpart partitions found on MTD device spi0.0
[    2.006711] Creating 3 MTD partitions on "spi0.0":
[    2.006719] 0x000000000000-0x000000100000 : "boot"
[    2.007304] 0x000000100000-0x000000140000 : "bootenv"
[    2.007837] 0x000000140000-0x000001740000 : "kernel"
[    2.009317] libphy: Fixed MDIO Bus: probed
[    2.010517] tun: Universal TUN/TAP device driver, 1.6
[    2.010524] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.010677] CAN device driver interface
[    2.011258] macb ff0e0000.ethernet: Not enabling partial store and forward
[    2.011824] libphy: MACB_mii_bus: probed
[    2.015315] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:00:02:90)
[    2.015324] TI DP83867 ff0e0000.etherne:09: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.etherne:09, irq=-1)
[    2.015913] usbcore: registered new interface driver asix
[    2.015966] usbcore: registered new interface driver ax88179_178a
[    2.015997] usbcore: registered new interface driver cdc_ether
[    2.016030] usbcore: registered new interface driver net1080
[    2.016061] usbcore: registered new interface driver cdc_subset
[    2.016091] usbcore: registered new interface driver zaurus
[    2.016136] usbcore: registered new interface driver cdc_ncm
[    2.016584] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.016590] ehci-pci: EHCI PCI platform driver
[    2.016847] usbcore: registered new interface driver uas
[    2.016889] usbcore: registered new interface driver usb-storage
[    2.017223] mousedev: PS/2 mouse device common for all mice
[    2.017672] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.017714] i2c /dev entries driver
[    2.017947] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    2.019037] usbcore: registered new interface driver uvcvideo
[    2.019042] USB Video Class driver (1.1.1)
[    2.019586] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff800950f000 with timeout 10s
[    2.019766] Bluetooth: HCI UART driver ver 2.3
[    2.019773] Bluetooth: HCI UART protocol H4 registered
[    2.019778] Bluetooth: HCI UART protocol BCSP registered
[    2.019781] Bluetooth: HCI UART protocol LL registered
[    2.019786] Bluetooth: HCI UART protocol ATH3K registered
[    2.019790] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.019836] Bluetooth: HCI UART protocol Intel registered
[    2.019879] Bluetooth: HCI UART protocol Broadcom registered
[    2.019884] Bluetooth: HCI UART protocol QCA registered
[    2.019923] usbcore: registered new interface driver bcm203x
[    2.019960] usbcore: registered new interface driver bpa10x
[    2.019997] usbcore: registered new interface driver bfusb
[    2.020037] usbcore: registered new interface driver btusb
[    2.020042] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.020100] usbcore: registered new interface driver ath3k
[    2.020231] EDAC MC: ECC not enabled
[    2.020446] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.020972] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1099999 KHz
[    2.021036] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    2.021463] sdhci: Secure Digital Host Controller Interface driver
[    2.021467] sdhci: Copyright(c) Pierre Ossman
[    2.021471] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.068410] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    2.116490] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    2.116781] ledtrig-cpu: registered to indicate activity on CPUs
[    2.116933] usbcore: registered new interface driver usbhid
[    2.116938] usbhid: USB HID core driver
[    2.118749] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    2.119315] xilinx-dp-snd-pcm dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    2.119349] xilinx-dp-snd-pcm dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    2.119531] PLL: shutdown
[    2.120475] Two devices are using vpll which is forbidden
[    2.120515] ------------[ cut here ]------------
[    2.120530] WARNING: CPU: 3 PID: 1 at /home/afzal/Mubashira/Petalinux_prj/dma_prj1/build/tmp/work-shared/plnx_aarch64/kernel-source/drivers/clk/zynqmp/pll.c:190 zynqmp_pll_set_rate+0x200/0x220
[    2.120535] Modules linked in:
[    2.120540]
[    2.120547] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.9.0-xilinx-v2017.4 #4
[    2.120551] Hardware name: xlnx,zynqmp (DT)
[    2.120556] task: ffffffc03fd66c00 task.stack: ffffffc03fd68000
[    2.120561] PC is at zynqmp_pll_set_rate+0x200/0x220
[    2.120566] LR is at zynqmp_pll_set_rate+0x200/0x220
[    2.120571] pc : [<ffffff8008459aa0>] lr : [<ffffff8008459aa0>] pstate: 60000045
[    2.120574] sp : ffffffc03fd6bb20
[    2.120578] x29: ffffffc03fd6bb20 x28: 0000000000000000
[    2.120583] x27: ffffff8008c7e298 x26: ffffff8009286000
[    2.120589] x25: 0000000001588800 x24: 0000000000000000
[    2.120594] x23: ffffffc06d5d2410 x22: ffffffc06d50f100
[    2.120600] x21: 0000000001fca055 x20: 0000000001fca055
[    2.120605] x19: 000000005ad20000 x18: 0000000000000010
[    2.120610] x17: 0000000000000000 x16: 0000000000000000
[    2.120615] x15: 0000000000000006 x14: ffffff808928b1d7
[    2.120621] x13: ffffff800928b1e5 x12: 00000000000000ff
[    2.120626] x11: ffffffc03fd6b880 x10: 0000000000000100
[    2.120631] x9 : 000000000000003d x8 : 2073692068636968
[    2.120636] x7 : 77206c6c70762067 x6 : ffffff800928b214
[    2.120642] x5 : 0000000000000006 x4 : 0000000000000000
[    2.120647] x3 : 0000000000000000 x2 : 0000000000000510
[    2.120652] x1 : ffffff800920a9c8 x0 : 000000000000002d
[    2.120657]
[    2.120664] ---[ end trace 5c69601721a909b0 ]---
[    2.120668] Call trace:
[    2.120675] Exception stack(0xffffffc03fd6b950 to 0xffffffc03fd6ba80)
[    2.120680] b940:                                   000000005ad20000 0000008000000000
[    2.120686] b960: ffffffc03fd6bb20 ffffff8008459aa0 ffffff800928d5f8 000000000000002d
[    2.120692] b980: ffffffc03fd6b9a0 ffffff80080d908c ffffff800928ac68 ffffff8008aec3d0
[    2.120698] b9a0: ffffffc03fd6ba40 ffffff80080d9364 000000005ad20000 0000000001fca055
[    2.120704] b9c0: 0000000001fca055 ffffffc06d50f100 ffffffc06d5d2410 0000000000000000
[    2.120710] b9e0: 0000000001588800 ffffff8009286000 000000000000002d ffffff800920a9c8
[    2.120716] ba00: 0000000000000510 0000000000000000 0000000000000000 0000000000000006
[    2.120722] ba20: ffffff800928b214 77206c6c70762067 2073692068636968 000000000000003d
[    2.120728] ba40: 0000000000000100 ffffffc03fd6b880 00000000000000ff ffffff800928b1e5
[    2.120734] ba60: ffffff808928b1d7 0000000000000006 0000000000000000 0000000000000000
[    2.120740] [<ffffff8008459aa0>] zynqmp_pll_set_rate+0x200/0x220
[    2.120748] [<ffffff80084547d8>] clk_change_rate+0x1e0/0x238
[    2.120755] [<ffffff8008454890>] clk_core_set_rate_nolock+0x60/0xc8
[    2.120761] [<ffffff8008454920>] clk_set_rate+0x28/0x58
[    2.120769] [<ffffff8008734b88>] xilinx_dp_codec_probe+0xd8/0x1e8
[    2.120776] [<ffffff8008504940>] platform_drv_probe+0x58/0xc0
[    2.120784] [<ffffff8008502de4>] driver_probe_device+0x1fc/0x2a8
[    2.120791] [<ffffff8008502f3c>] __driver_attach+0xac/0xb0
[    2.120797] [<ffffff8008500e34>] bus_for_each_dev+0x64/0xa0
[    2.120804] [<ffffff80085025d0>] driver_attach+0x20/0x28
[    2.120810] [<ffffff8008502120>] bus_add_driver+0x110/0x230
[    2.120817] [<ffffff8008503720>] driver_register+0x60/0xf8
[    2.120822] [<ffffff8008504878>] __platform_driver_register+0x40/0x48
[    2.120831] [<ffffff8008c60f8c>] xilinx_dp_codec_driver_init+0x18/0x20
[    2.120839] [<ffffff80080830b8>] do_one_initcall+0x38/0x128
[    2.120846] [<ffffff8008c30c94>] kernel_init_freeable+0x140/0x1e0
[    2.120852] [<ffffff80089462d8>] kernel_init+0x10/0x100
[    2.120858] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    2.121061] Write failed to divider address:fd1a00c0
[    2.121427] PLL: enable
[    2.121627] xilinx-dp-snd-codec dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    2.122553] xilinx-dp-snd-card dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    2.122667] xilinx-dp-snd-card dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    2.123809] xilinx-dp-snd-card dp_snd_card: Xilinx DisplayPort Sound Card probed
[    2.123922] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.162395] mmc0: new HS200 MMC card at address 0001
[    2.162661] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    2.162769] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    2.162875] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    2.163969] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    2.164771]  mmcblk0: p1
[    2.228621] Netfilter messages via NETLINK v0.30.
[    2.228752] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.228807] Initializing XFRM netlink socket
[    2.228865] NET: Registered protocol family 10
[    2.229350] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.229398] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.229780] NET: Registered protocol family 17
[    2.229794] NET: Registered protocol family 15
[    2.229810] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.229815] Ebtables v2.0 registered
[    2.229843] can: controller area network core (rev 20120528 abi 9)
[    2.229878] NET: Registered protocol family 29
[    2.229883] can: raw protocol (rev 20120528)
[    2.229888] can: broadcast manager protocol (rev 20161123 t)
[    2.229895] can: netlink gateway (rev 20130117) max_hops=1
[    2.229965] Bluetooth: RFCOMM TTY layer initialized
[    2.229974] Bluetooth: RFCOMM socket layer initialized
[    2.229985] Bluetooth: RFCOMM ver 1.11
[    2.229992] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.229996] Bluetooth: BNEP filters: protocol multicast
[    2.230003] Bluetooth: BNEP socket layer initialized
[    2.230008] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.230014] Bluetooth: HIDP socket layer initialized
[    2.230221] 9pnet: Installing 9P2000 support
[    2.230240] Key type dns_resolver registered
[    2.230708] registered taskstats version 1
[    2.231138] Btrfs loaded, crc32c=crc32c-generic
[    2.237204] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps
[    2.252409] sdhci-arasan ff170000.sdhci: : Timeout for Buffer Read Ready interrupt, back to fixed sampling clock
[    2.252415] mmc1: tuning execution failed: -5
[    2.252426] mmc1: error -5 whilst initialising SD card
[    2.318691] ata1: SATA link down (SStatus 0 SControl 330)
[    2.318732] ata2: SATA link down (SStatus 0 SControl 330)
[    4.268396] console [ttyPS0] enabled
[    4.272316] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps
[    4.286256] [drm] load() is defered & will be called again
[    4.292333] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
[    4.335087] xilinx-drm-dp fd4a0000.dp: device found, version 4.010
[    4.341190] xilinx-drm-dp fd4a0000.dp: Display Port, version 1.0200 (tx)
[    4.349180] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.354592] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.362479] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x02010010
[    4.371125] xhci-hcd xhci-hcd.0.auto: irq 221, io mem 0xfe200000
[    4.377207] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.383911] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.391112] usb usb1: Product: xHCI Host Controller
[    4.395971] usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.4 xhci-hcd
[    4.402568] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.407754] hub 1-0:1.0: USB hub found
[    4.411445] hub 1-0:1.0: 1 port detected
[    4.415509] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.420920] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.428595] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.436707] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.443411] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.450613] usb usb2: Product: xHCI Host Controller
[    4.455473] usb usb2: Manufacturer: Linux 4.9.0-xilinx-v2017.4 xhci-hcd
[    4.462070] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.467213] hub 2-0:1.0: USB hub found
[    4.470902] hub 2-0:1.0: 1 port detected
[    4.475961] OF: graph: no port node found in /xilinx_drm
[    4.481188] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.487780] [drm] No driver support for vblank timestamp query.
[    8.587238] xilinx-drm xilinx_drm: No connectors reported connected with modes
[    8.594381] [drm] Cannot find any crtc or sizes - going 1024x768
[    8.606944] Console: switching to colour frame buffer device 128x48
[    8.618117] xilinx-drm xilinx_drm: fb0:  frame buffer device
[    8.636404] [drm] Initialized xilinx_drm 1.0.0 20130509 on minor 0
[   12.260392] mmc1: Timeout waiting for hardware cmd interrupt.
[   12.266043] sdhci: =========== REGISTER DUMP (mmc1)===========
[   12.271859] sdhci: Sys addr: 0x00000000 | Version:  0x00001002
[   12.277675] sdhci: Blk size: 0x00007040 | Blk cnt:  0x00000000
[   12.283491] sdhci: Argument: 0x00000000 | Trn mode: 0x00000010
[   12.289306] sdhci: Present:  0x01c70001 | Host ctl: 0x0000001f
[   12.295122] sdhci: Power:    0x0000000f | Blk gap:  0x00000080
[   12.300938] sdhci: Wake-up:  0x00000000 | Clock:    0x00000003
[   12.306753] sdhci: Timeout:  0x00000004 | Int stat: 0x00000000
[   12.312569] sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[   12.318384] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[   12.324200] sdhci: Caps:     0x31ecc881 | Caps_1:   0x00002007
[   12.330016] sdhci: Cmd:      0x00000102 | Max curr: 0x00000000
[   12.335831] sdhci: Host ctl2: 0x0000000b
[   12.339738] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000007005920c
[   12.346247] sdhci: ===========================================
[   22.500390] mmc1: Timeout waiting for hardware cmd interrupt.
[   22.506046] sdhci: =========== REGISTER DUMP (mmc1)===========
[   22.511862] sdhci: Sys addr: 0x00000000 | Version:  0x00001002
[   22.517677] sdhci: Blk size: 0x00000000 | Blk cnt:  0x00000000
[   22.523493] sdhci: Argument: 0x00000c00 | Trn mode: 0x00000000
[   22.529309] sdhci: Present:  0x01f70000 | Host ctl: 0x00000001
[   22.535124] sdhci: Power:    0x0000000f | Blk gap:  0x00000080
[   22.540940] sdhci: Wake-up:  0x00000000 | Clock:    0x00004e47
[   22.546756] sdhci: Timeout:  0x00000000 | Int stat: 0x00018000
[   22.552572] sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[   22.558387] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000001
[   22.564203] sdhci: Caps:     0x31ecc881 | Caps_1:   0x00002007
[   22.570018] sdhci: Cmd:      0x0000341a | Max curr: 0x00000000
[   22.575833] sdhci: Host ctl2: 0x00000000
[   22.579741] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[   22.586249] sdhci: ===========================================
[   29.644388] INFO: rcu_sched self-detected stall on CPU
[   29.649440]  3-...: (5249 ticks this GP) idle=37d/140000000000001/0 softirq=192/192 fqs=2625
[   29.657942]   (t=5250 jiffies g=-212 c=-213 q=51)
[   29.662631] Task dump for CPU 3:
[   29.665842] swapper/0       R  running task        0     1      0 0x00000002
[   29.672873] Call trace:
[   29.675312] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[   29.680688] [<ffffff80080882e4>] show_stack+0x14/0x20
[   29.685723] [<ffffff80080c0f2c>] sched_show_task+0x94/0xf0
[   29.691190] [<ffffff80080c3158>] dump_cpu_task+0x40/0x50
[   29.696487] [<ffffff800812ee14>] rcu_dump_cpu_stacks+0xb4/0xe8
[   29.702302] [<ffffff80080e9074>] rcu_check_callbacks+0x67c/0x860
[   29.708291] [<ffffff80080ec72c>] update_process_times+0x34/0x60
[   29.714193] [<ffffff80080fbc08>] tick_sched_handle.isra.4+0x38/0x48
[   29.720441] [<ffffff80080fbc5c>] tick_sched_timer+0x44/0x90
[   29.725998] [<ffffff80080ed1e8>] __hrtimer_run_queues+0xf0/0x178
[   29.731986] [<ffffff80080ed578>] hrtimer_interrupt+0x98/0x1c8
[   29.737718] [<ffffff80086e1e40>] arch_timer_handler_phys+0x30/0x40
[   29.743880] [<ffffff80080dfa70>] handle_percpu_devid_irq+0x78/0x128
[   29.750128] [<ffffff80080da774>] generic_handle_irq+0x24/0x38
[   29.755856] [<ffffff80080dadec>] __handle_domain_irq+0x5c/0xb8
[   29.761672] [<ffffff80080814cc>] gic_handle_irq+0x64/0xc0
[   29.767053] Exception stack(0xffffffc03fd6bb40 to 0xffffffc03fd6bc70)
[   29.773477] bb40: 0000000000000003 ffffffc06ff89418 0000000000000000 0000000000000000
[   29.781289] bb60: 0000000000000000 0000000000000007 ffffff800929fd10 00000000260c177d
[   29.789101] bb80: 0000000000061a7c 00003d09000198c8 fffffffffffe6738 00000000003d0900
[   29.796913] bba0: 003d090000000000 0000000000000000 0000000000000008 ffffffffffffffff
[   29.804725] bbc0: 0000000000000000 0000000000000001 0000000000000000 ffffffc06ffbf900
[   29.812537] bbe0: ffffff80091f7478 ffffffc06ffbf908 ffffff80091ce800 0000000000000001
[   29.820349] bc00: ffffff80080ed308 0000000000000000 0000000000000008 ffffff80091f7000
[   29.828162] bc20: ffffff80091f7344 ffffffc03fd6bc70 ffffff80081009f4 ffffffc03fd6bc70
[   29.835974] bc40: ffffff8008100a34 0000000080000045 0000000000000001 ffffff80080ed308
[   29.843784] bc60: ffffffffffffffff ffffff80081009f4
[   29.848646] [<ffffff80080827b0>] el1_irq+0xb0/0x140
[   29.853508] [<ffffff8008100a34>] smp_call_function_many+0x264/0x2c8
[   29.859757] [<ffffff8008100afc>] on_each_cpu+0x34/0x60
[   29.864878] [<ffffff80080ed3e4>] clock_was_set+0x1c/0x28
[   29.870174] [<ffffff80080f3008>] do_settimeofday64+0x100/0x180
[   29.875990] [<ffffff8008c5a6b4>] rtc_hctosys+0x8c/0xe0
[   29.881110] [<ffffff80080830b8>] do_one_initcall+0x38/0x128
[   29.886666] [<ffffff8008c30c94>] kernel_init_freeable+0x140/0x1e0
[   29.892742] [<ffffff80089462d8>] kernel_init+0x10/0x100
[   29.897949] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[   32.740390] mmc1: Timeout waiting for hardware cmd interrupt.
[   32.746040] sdhci: =========== REGISTER DUMP (mmc1)===========
[   32.751856] sdhci: Sys addr: 0x00000000 | Version:  0x00001002
[   32.757672] sdhci: Blk size: 0x00000000 | Blk cnt:  0x00000000
[   32.763487] sdhci: Argument: 0x80000c08 | Trn mode: 0x00000000
[   32.769303] sdhci: Present:  0x01f70000 | Host ctl: 0x00000001
[   32.775119] sdhci: Power:    0x0000000f | Blk gap:  0x00000080
[   32.780934] sdhci: Wake-up:  0x00000000 | Clock:    0x00004e47
[   32.786750] sdhci: Timeout:  0x00000000 | Int stat: 0x00018000
[   32.792566] sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[   32.798381] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000001
[   32.804197] sdhci: Caps:     0x31ecc881 | Caps_1:   0x00002007
[   32.810013] sdhci: Cmd:      0x0000341a | Max curr: 0x00000000
[   32.815828] sdhci: Host ctl2: 0x00000000
[   32.819735] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[   32.826243] sdhci: ===========================================
[   42.980391] mmc1: Timeout waiting for hardware cmd interrupt.
[   42.986043] sdhci: =========== REGISTER DUMP (mmc1)===========
[   42.991859] sdhci: Sys addr: 0x00000000 | Version:  0x00001002
[   42.997674] sdhci: Blk size: 0x00000000 | Blk cnt:  0x00000000
[   43.003490] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[   43.009306] sdhci: Present:  0x01f70000 | Host ctl: 0x00000001
[   43.015121] sdhci: Power:    0x0000000f | Blk gap:  0x00000080
[   43.020937] sdhci: Wake-up:  0x00000000 | Clock:    0x00004e47
[   43.026752] sdhci: Timeout:  0x00000000 | Int stat: 0x00018001
[   43.032568] sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[   43.038384] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000001
[   43.044200] sdhci: Caps:     0x31ecc881 | Caps_1:   0x00002007
[   43.050015] sdhci: Cmd:      0x00000000 | Max curr: 0x00000000
[   43.055830] sdhci: Host ctl2: 0x00000000
[   43.059737] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[   43.066246] sdhci: ===========================================
[   53.220391] mmc1: Timeout waiting for hardware cmd interrupt.
[   53.226045] sdhci: =========== REGISTER DUMP (mmc1)===========
[   53.231861] sdhci: Sys addr: 0x00000000 | Version:  0x00001002
[   53.237677] sdhci: Blk size: 0x00000000 | Blk cnt:  0x00000000
[   53.243493] sdhci: Argument: 0x000001aa | Trn mode: 0x00000000
[   53.249308] sdhci: Present:  0x01f70000 | Host ctl: 0x00000001
[   53.255124] sdhci: Power:    0x0000000f | Blk gap:  0x00000080
[   53.260940] sdhci: Wake-up:  0x00000000 | Clock:    0x00004e47
[   53.266755] sdhci: Timeout:  0x00000000 | Int stat: 0x00018001
[   53.272571] sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[   53.278387] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000001
[   53.284202] sdhci: Caps:     0x31ecc881 | Caps_1:   0x00002007
[   53.290018] sdhci: Cmd:      0x0000081a | Max curr: 0x00000000
[   53.295833] sdhci: Host ctl2: 0x00000000
[   53.299740] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[   53.306249] sdhci: ===========================================
[   63.460391] mmc1: Timeout waiting for hardware cmd interrupt.
[   63.466048] sdhci: =========== REGISTER DUMP (mmc1)===========
[   63.471864] sdhci: Sys addr: 0x00000000 | Version:  0x00001002
[   63.477680] sdhci: Blk size: 0x00000000 | Blk cnt:  0x00000000
[   63.483495] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[   63.489311] sdhci: Present:  0x01f70000 | Host ctl: 0x00000001
[   63.495127] sdhci: Power:    0x0000000f | Blk gap:  0x00000080
[   63.500942] sdhci: Wake-up:  0x00000000 | Clock:    0x00004e47
[   63.506758] sdhci: Timeout:  0x00000000 | Int stat: 0x00018000
[   63.512574] sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[   63.518389] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000001
[   63.524205] sdhci: Caps:     0x31ecc881 | Caps_1:   0x00002007
[   63.530021] sdhci: Cmd:      0x00000502 | Max curr: 0x00000000
[   63.535836] sdhci: Host ctl2: 0x00000000
[   63.539743] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[   63.546251] sdhci: ===========================================
[   73.700391] mmc1: Timeout waiting for hardware cmd interrupt.
[   73.706042] sdhci: =========== REGISTER DUMP (mmc1)===========
[   73.711858] sdhci: Sys addr: 0x00000000 | Version:  0x00001002
[   73.717674] sdhci: Blk size: 0x00000000 | Blk cnt:  0x00000000
[   73.723489] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[   73.729305] sdhci: Present:  0x01f70000 | Host ctl: 0x00000001
[   73.735121] sdhci: Power:    0x0000000f | Blk gap:  0x00000080
[   73.740936] sdhci: Wake-up:  0x00000000 | Clock:    0x00004e47
[   73.746752] sdhci: Timeout:  0x00000000 | Int stat: 0x00018000
[   73.752568] sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[   73.758383] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000001
[   73.764199] sdhci: Caps:     0x31ecc881 | Caps_1:   0x00002007
[   73.770015] sdhci: Cmd:      0x00000502 | Max curr: 0x00000000
[   73.775830] sdhci: Host ctl2: 0x00000000
[   73.779737] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[   73.786245] sdhci: ===========================================
Re: Petalinux image not booting properly
You are getting the error here:
This looks like the known issue discussed in the AR below:
https://www.xilinx.com/support/answers/69764.html
Can you open the PS configuration in the Vivado IPI, and make the changes mentioend in the AR, re-generate the output products,
re-export to SDK and update the DT with this HDF file
petalinux-build -x device-tree
Hi, thank you for your answer. I will try this as well.
Do you think that this error is also being caused because of the PLL shutdown error?
