Petalinux install - permission denied petalinux-env-check in /tmp
I am trying to install the latest version of petalinux on ubuntu 16.04 but I am facing problems when installing with the following command:
ariel@ariel-PC:~/Downloads$ ./petalinux-v2017.4-final-installer.run /home/ariel/Petalinux/
And these are the issues:
INFO: Checking installation environment requirements...
./petalinux-v2017.4-final-installer.run: line 183: /tmp/tmp.1V0IDGq0Q6/./tools/common/petalinux/utils/petalinux-env-check: Permission denied
WARNING: Please install required packages.
I have the ownership of tmp:
ariel@ariel-PC:~/Downloads$ ls -ld /tmp/
drwxrwxrwx 15 root ariel 560 Mar 15 10:22 /tmp/
And I have installed the required packages according to the user guide UG1144
sudo apt-get install python3 tofrodos iproute gawk xvfb gcc git make net-tools libncurses5-dev tftpd zlib1g-dev zlib1g:i386 libssl-dev flex bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev screen pax gzip
Should I change permissions for some other folder?
Thanks for the help.
Re: Petalinux install - permission denied petalinux-env-check in /tmp
I found the issue. I have /tmp mounted on RAM, by changing /etc/fstab adding the following line:
tmpfs /tmp tmpfs defaults,noatime,nosuid,nodev,noexec,mode=1777,size=5G 0 0
I commented it, installed petalinux and uncommented it and now petalinux is installed.
Mentor watari
Mentor
Hi @aripod
Could you use the following command ?
I resolved petalinux install issue with this command.
% bash ./petalinux-v2017.4-final-installer.run /home/ariel/Petalinux
Best regards,
Hello @watari,
The issue remains:
ariel@ariel-PC:~/Downloads$ bash ./petalinux-v2017.4-final-installer.run /home/ariel/Petalinux/
INFO: Checking installer checksum...
INFO: Extracting PetaLinux installer...
LICENSE AGREEMENTS
PetaLinux SDK contains software from a number of sources.  Please review
the following licenses and indicate your acceptance of each to continue.
You do not have to accept the licenses, however if you do not then you may
not use PetaLinux SDK.
Use PgUp/PgDn to navigate the license viewer, and press 'q' to close
Press Enter to display the license agreements
Do you accept Xilinx End User License Agreement? [y/N] > y
Do you accept Webtalk Terms and Conditions? [y/N] > y
Do you accept Third Party End User License Agreement? [y/N] > y
./petalinux-v2017.4-final-installer.run: line 183: /tmp/tmp.U8HAxFVIAT/./tools/common/petalinux/utils/petalinux-env-check: Permission denied
Please refer to the PetaLinux Tools Installation Guide.
Check the troubleshooting guide at the end of that manual, and if you are
unable to resolve the issue please contact customer support with file:
   /home/ariel/Downloads/petalinux_installation_log
Scholar austin
in bash:
mkdir plinux
sudo chmod 755 plinux
cd plinux
./petalinux-v2017.4-final-installer.run /home/austin/plinux
worked for me.  Then one has to resolve all dependencies ....
sudo apt-get install build-essential gcc-multilib gcc-4.8-multilib g++-multilib g++-4.8-multilib lib32z1 lib32ncurses5 lib32bz2-1.0 libc6-dev libgmp-dev libmpfr-dev libmpc-dev
sudo dpkg --add-architecture i386
sudo apt-get install -y python tofrodos iproute2 gawk xvfb gcc git make net-tools libncurses5-dev tftpd zlib1g-dev libssl-dev flex bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev zlib1g:i386 screen pax
sudo apt-get dist-upgrade
Austin Lesea
Principal Engineer
Xilinx San Jose
@austin,
The error is with
/home/ariel/Downloads/./petalinux-v2017.4-final-installer.run: line 183: /tmp/tmp.bpdO5iBHk0/./tools/common/petalinux/utils/petalinux-env-check: Permission denied
Which is strange because I can create folders and files in /tmp.
ariel@ariel-PC:~/Petalinux$ ls -ld /tmp/
drwxrwxrwt 14 root ariel 360 Mar 16 08:38 /tmp/
Is it possible to change so it uses as temporary directory ~/Petalinux/tmp for example?
Scholar austin
I advise you to use a directory,
under your username, like I did. (/home/austin/plinux as noted)
Did not have any luck at all (just did not work) for me to put the directory under the root (for me).
Austin Lesea
Principal Engineer
Xilinx San Jose
@austin,
I am using a directory in my home to install :
But the installation is using /tmp to extract the files I believe. That is the issue but I cannot understand why I can create files and foldes in /tmp but not the petalinux installer.
@austin, I have just followed yours steps again to update all the dependencies, I copied the .run file to a folder in my home but I still have the error with /tmp.
What should be the permission for the script? I set it to 755:
sudo chmod 755 petalinux-v2017.4-final-installer.run
Scholar austin
chmod applies to the directory, not the command,
do not use sudo to execute the install
Austin Lesea
Principal Engineer
Xilinx San Jose
Yes of course it does not apply for the command....I am not going to launch the script with chmod.... I meant for the folder in my home to install petalinux......775 I believe? or 777. Regardless, none of them solve the issue as the script creates a folder in /tmp called /tmp/tmp.random_string which is where it is giving the permission denied error.....which is the root of the problem. That is why I asked if there is a way to change that temporary folder to use the same one where I want to install petalinux (in my home) to avoid any permission errors.
@austin,
I changed:
ariel@ariel-PC:~/Downloads$ sudo chmod 755 /home/ariel/petalinux/
ariel@ariel-PC:~/Downloads$ sudo chmod +x /home/ariel/Downloads/petalinux-v2017.4-final-installer.run
ariel@ariel-PC:~/Downloads$ sudo chmod 1777 /tmp
And then:
ariel@ariel-PC:~/Downloads$ ./petalinux-v2017.4-final-installer.run /home/ariel/petalinux/
So just to be 100% sure all permissions are correctly. Still, I get the same issue with /tmp
./petalinux-v2017.4-final-installer.run: line 183: /tmp/tmp.dPB3hFJiuy/./tools/common/petalinux/utils/petalinux-env-check: Permission denied
