surajrgupta
Petalinux installation failing - Integrity check fail -v2020.1
I have been trying to install petalinux-v2020.1 on ubuntu 18.04.4 system.
On progressing with cli,
after INFO: Checking PetaLinux installer integrity...
I am get checksum mismatch error.
I have attached the log for reference.
I am also getting these errors which are not reflected in log.
tail: invalid number of lines: '+'
xz: (stdin): File format not recognized
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Kindly help..
surajrgupta
Can anyone verify if the petalinux source at https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html is corrrect?
The 2020.1 Petalinux version is 1.53 GB while 2019.2 petalinux version is 7.92 GB.
Can any xilinx guy explain this.
Thanks in advance
aravindb
HI @surajrgupta
Yes. you are referring the right file. I just want to know, have you have you installed all the required packages recommended in this ug1144 guide.
Refer this guide(Section: Installation Requirements & Packages and Linux Workstation Environments)
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug1144-petalinux-tools-reference-guide.pdf
Thanks & regards
Aravind
surajrgupta
Hi @aravindb
I had installed all the prerequisite libraries. Verified it also now.
The problem still persists.
