giorgio.lopez
Petalinux issues on Ubuntu 14.04 with dpkg
I know Ubuntu is not an officially supported OS for PetaLinux, but I was wondering whether anyone has faced/solved this issue before:
When trying to build a project I see
[INFO ] pre-build linux/rootfs/uWeb
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[INFO ] build zynq_fsbl
[INFO ] Expanding stagefs
[ERROR] dpkg: attenzione: "start-stop-daemon" non è stato trovato in PATH o non è un eseguibile
[ERROR] E: Sub-process /opt/Xilinx/petalinux-v2014.4-final/tools/packagemanager/bin/dpkg returned an error code (1) [ERROR] make[2]: *** [.pkg_stagefs] Errore 255
[ERROR] make[1]: *** [sub_build_component_/none/packages-repo/single/plnx-repo]
Errore 2
ERROR: Failed to build linux
Now, I think the issue here is with dpkg and start-stop-daemon.
I already tried specifying manually on the PATH variable the dpkg inside of the petalinux tree, and a solution on the forum regarding a patch for the Makefile of the packages-repo didn't help either.
Any idea anyone?
Giorgio
