Participant sponduri
Petalinux kernel hanging randomly when booting up
I am using petalinux 2018.3 to build linux for a custom board. The linux boots properly for most of the time but randomly the boot process hangs at the following stages
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.0 (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP Thu May 30 23:35:25 UTC 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: xlnx,zynqmp
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '')
[ 0.000000] bootconsole [cdns0] enabled
[and]
Device: mmc@ff160000
Manufacturer ID: 15
OEM: 100
Tran Speed: 200000000
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 512 KiB ENH
reading image.ub
5593196 bytes read in 389 ms (13.7 MiB/s)
Using 'conf@system-top.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x100000f8
Data Size: 5555760 Bytes = 5.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: 93fff9bd1085dc7934d27b4ad3928e7ccdfbc39a
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x1054c82c
Data Size: 35532 Bytes = 34.7 KiB
Hash algo: sha1
Hash value: 362a9ef3974a690fcfd3baf877184f194cf756a4
Booting using the fdt blob at 0x1054c82c
Uncompressing Kernel Image ... OK
Loading Device Tree to 0000000007ff4000, end 0000000007fffacb ... OK
Starting kernel ...
I have cross checked the serial device addresses in device tree and also the kernel arguments I am using are
earlycon=cdns,0xff000000 console=ttyPS0,115200n8 clk_ignore_unused root=/dev/mmcblk1p2 rw rootwait uio_pdrv_genirq.of_id=generic-uio
Could some one please guide me to possible reasons on why this is happening
Re: Petalinux kernel hanging randomly when booting up
Do you have xsdb or vivado/sdk connected through jtag? Please disable cpu-idle by following the AR below.
https://www.xilinx.com/support/answers/69143.html
Not sure if I am facing the same problem as described in the article but I made the necessary changes in my kernel and have to test it. Will comment on the issue after adequately testing it
