Petalinux non-volatile storage
I'm booting my ZC702 board from SD Card. To do so, I've downloaded 2018.3-zc702-release.tar.xz pre-built image from https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57639129/Zynq+2018.3+Release .
Everything is fine while booting but I'm loosing any changes I made on Linux after a re-boot. So, I think it writes into RAM but I want to keep my changes.
What could be possibly wrong here and how can I solve this issue?
Tags (3)
Re: Petalinux non-volatile storage
Hi @oerbakan,
You are right, by default the initramfs is  added with kernel. with this rootfs whatever the changes you do it will be lost once the board is reset.
Can you please use the rootfs from your SDcard 2nd partition, so that whatever the changes you do , it will be saved even for next boot. You will not lost once the power off.
Please add below config changes :
1. petalinux-config -c kernel
General setup --->
[ ] Initial RAM filesystem and RAM disk (initramfs/initrd) support  ---> By default it is enabled/selected , you can disable it.
save & exit
petalinux-build
2. Extract the rootfs to sdcard 2nd partition
sudo tar –xvf rootfs.tar.bz2  –C /media/sdcard/
 sync
3.Power on the board &  Once you get u-boot console run below command:
4. change the bootargs to pick the rootfs from sdcard 2nd partition.
setenv bootargs 'console=ttyPS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
5.boot
Thanks & regards
Aravind
Hi @oerbakan,
General setup --->
save & exit
petalinux-build
 sync
5.boot
Thanks & regards
Aravind
