Petalinux on XUP-V2Pro
Hi!
I'm a new user of Xilinx board.
I have a problem when load petalinux on my board.
My board is XUP-Virtex 2 Pro, and it has a SDRAM.
When I build the hardware platform (with EDK 10.1SP3), I use microblaze, unmarke "cache setup", add a timer and marke all interrupts.  I modify system.mss and system.xmp in order to associate this hardware platform with petalinux, and make the bits, libs and init_bram.
I compile the petalinux (ver. 0.40-rc4), and I follow this steps:
xmd
XMD% connect mb mdm -cable type xilinx_platformusb port usb21
XMD% dow -data images/image.bin 0x90000000
XMD% rst
XMD% con 0x90000000
And I can see on the terminal (connected with serial cable):
Found romfs @ 0x900b108c (0x000f7000)
#### klimit 901c880 ####
Moving 0x000f7000 bytes from 0x900b108c to 0x901c8868
New klimit  901c880
And the system freeze here.
Please, what can I do to load petalinux?
Thanks!!!!
Message Edited by themasteracf on 09-10-2009 04:35 AM
Message Edited by themasteracf on 09-10-2009 05:50 AM
I don't have any experience with the petalogix distro, you may want to go to the Petalinux mailing list as I know one exists.
-- John
