pfincher
Petalinux root ram filesystem location
We are using Petalinux on the ZCU-102 with a RAM root filesystem. I am trying to understand how the kernel knows where in memory the root filesystem is located. In the following how does it point to 0x79E5000:
Loading Ramdisk to 079e5000, end 07fff0d8 ... OK
Loading Device Tree to 00000000079d7000, end 00000000079e41ff ... OK
Any help/guidance is apreciated.
Paul
sandeepg
Hi @pfincher,
Which boot mode are you using and what is your "Image Packaging Configuration" set to in petalinux-config option.
Also please provide the complete boot logs.
Sandeep
pfincher
Hi Sandeepg,
   I am using SD to get U-boot but then we are using tftpboot/bootm to boot the image. See the attached boot log.
Paul
