Visitor bmurali
Petalinux rootfs modifications
I would like to install the linux-wpan tool for interfacing the zynq with adf7242 transceiver.
How do I install this application in PetaLinux rootfs before writing to SD card?
linux-wpan compilation, installation itself depends on multiple other tools. This also should be installed.
Please guide me on this.
Murali
Re: Petalinux rootfs modifications
What is the version of Xilinx tools are you using?
FYI: please check whether any of the below answer records are helpful to you
https://www.xilinx.com/support/answers/59073.html
https://www.xilinx.com/support/answers/59412.html
Visitor bmurali
Thanks for the response.
I cam across this informative post to integrate the wpan tools in to rootfs: http://wiki.beyondlogic.org/index.php?title=Cross_Compiling_Linux_wpan_tools_for_ARM
This resolves the query.
Murali
Visitor bmurali
This is NOT yet successful.
I have cross compiled as it is mentioned in the above link, but I am not able to run the iwpan application on zynq. It says the iwpan not found, even though it is is right there in the bin folder.
I followed the user application flow in petalinux. When I try to compile, I am getting oe_runmake failed error.
Murali
Have you followed the steps properly as listed in Petalinux User Gudie UG1144. What is the error you are seeing?
Page - 51 : https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
Debraj
