Visitor bmurali
Petalinux rootfs sd card option doesnt generate the cpio file
Hi there,
In PetaLinux, I am setting the configuration of the rootfs to be SD card. But the rootfs.cpio file doesn't get generated in the images/linux folder. It does get generated when the configuration of the rootfs is set to INITRAMFS.
Is it designed to be like this?
How do I generate the rootfs.cpio even when the rootfs config is set SD card?
Murali
Visitor bmurali
Re: Petalinux rootfs sd card option doesnt generate the cpio file
This is for Petalinux 2016.1
If you did not refer below user guides then it is worth to refer . You may get some debug clues
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
https://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_2/ug977-petalinux-getting-started.pdf
Visitor bmurali
I am in constant reference of the userguides suggested. But the cpio file will not be generated if one selects the rootfs to be SD card. But please not that this is not the case for PL2016.4, it does generate the ext* files..
We have a long and interesting discussion as per the thread: https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2016-4-boot-from-SD-with-ext4-rootfs/td-p/742310
For SD, you need to use rootfs.ext4 generated inside the images/linux folder. The rootfs.cpio is still generated but the .ext4 would solve your purpose.
Debraj
