Petalinux shell problem
Petalinux needs the shell to be bash. I have changed my default shell to bash using the chsh -s /bin/bash command. However the tools do not run, for example
david@ubuntu:/media/disk2/projects/Avnet-Digilent-ZedBoard-2014.2$ petalinux-create -t modules -n mymodule --enable
INFO: Create modules: mymodule
INFO: New modules successfully created in /media/disk2/projects/Avnet-Digilent-ZedBoard-2014.2/components/modules/mymodule
INFO: Enabling created component...
ERROR: Failed to oldconfig linux/rootfs!
/bin/sh: 1: arithmetic expression: expecting primary: ""
/bin/sh: 1: pushd: not found
/bin/sh: 1: popd: not found
make: *** [oldconfig] Error 127
ERROR: Failed to config component linux/rootfs
ERROR: Failed to enable the component because of configuration failure.
ERROR: However, failed to enable created component.
seems scripts use /bin/sh and that is not bash !!!
using UBUNTU 14.04  32bit as my Linux
Any suggestions
Dave
