aaron_b1
Petalinux software needs to switching from one platform to another
I have a petalinux project that I'd like to be able to switch from one hardware definition file to another.
More specifically, I'd like to be able to build my software sometimes for a Trenz TE0808 ultrascale module, and other times for a zcu102 development board.
The trenz module has a different meta-user/recipes-bsp/device-tree/files/system-user.dtsi and meta-user/recipes-bsp/u-boot/files/platform-top.h - though I have my own changes to system-user.dtsi that need to play nicely with whatever trenz needs.
I currently use petalinux, and in between each build-type I remove build/ components/ and project-spec/meta-plnx-generated/.  I then have to manually place the appropriate platform-top.h and system-user.dtsi files.
I've procrastinated looking in to yocto.  I'm not really familiar with it, but I wonder if it might be able to handle these types of changes more easily?
aravindb
HI @aaron_b1
Please create a two petalinux projects, so that it will easy to build & no need to copy required files every  build.  and we can avoid unneccessary issues.
Thanks & regadrs
Aarvind
stephenm
If the only difference is devicetree nodes then you could patch the dtg to include your dtsi file ( like is done for dev boards). Then just reference this in the petalinux-config -> DTG settings.
Same would apply for yocto
aaron_b1
I'm sorry, I really don't understand your answer.
"patch the dtg to include your dtsi file"
By putting a system-user.dtsi in recipes-bsp/device-tree, aren't I already doing this?
"Then just reference this in the petalinux-config -> DTG settings"
I'm not familiar with this.  What does "DTG" stand for here, and what does selecting this do in the petalinux config?
stephenm
DTG is the device tree generator. You can update this in the system-user.dtsi. However, if you want to automate this per board. You can add your board.dtsi to the dtg and create a patch
git clone https://github.com/Xilinx/device-tree-xlnx
cd device-tree-xlnx
git checkout xilinx-v2018.3
Place your board dtsi files here
device_tree/data/kernel_dtsi/2018.3/BOARDS
git diff xilinx_v2018.3 < 0001_add_custom_dtsi.patch
Place this patch in the files dir in fsbl recipe and update the fsbl  bbappend to use this SRC_URI_append += " file://0001_add_custom_dtsi.patch"
aaron_b1
Thanks,  This sounds handy.
Does this patching technique work if the device tree information I have is a small segment of a device tree?  For instance, when building for the ZCU102, all I have is a fragment in system-user.dtsi that would tell the PTP driver what frequency the timestamping clock is.
/include/ "system-conf.dtsi"
        amba {
                ethernet@ff0e0000 {
                        tsu-clk = <250000000>;
In the other board, based on a Trenz module, I keep the previous little segment, and add a bunch of text provided by the trenz sample project.  I have no idea how much  of it is critical
/* default */
/* SD */
&sdhci1 {
        // disable-wp;
        no-1-8-v;
/* ETH PHY */
&gem3 {
        phy-handle = <&phy0>;
        phy0: phy0@1 {
                device_type = "ethernet-phy";
                reg = <1>;
/* QSPI */
&qspi {
    #address-cells = <1>;
    #size-cells = <0>;
    status = "okay";
    flash0: flash@0 {
        // compatible = "n25q256a";
        reg = <0x0>;
        #size-cells = <1>;
/* I2C */
&i2c0 {
    i2cswitch@73 { // u
        compatible = "nxp,pca9548";
        #size-cells = <0>;
        reg = <0x73>;
        i2c-mux-idle-disconnect;
The *.dtsi in device_tree/data/kernel_dtsi/2017.3/BOARD/ look like they are FULL device trees.
