Visitor gpats
Petalinux system library hardfp support
I am using Petalinux 2015.4 on a Zynq Zedboard 7000. My system libraries are softfp compliant. Is there any way I can change petalinux to support these libraries for hardfp architechture? These are needed by an API.
readelf -h ld-2.21.so | grep Flags
 gives:
Flags: 0x5000202, Version5 EABI, soft-float ABI, <unknown>
this is causing an error while compiling a sample application for the API:
sudo arm-linux-gnueabi-g++ -Os -g -fomit-frame-pointer -pipe -fno-common -fno-builtin -Wall -march=armv7-a -mfloat-abi=hard -marm -mthumb-interwork -mtune=cortex-a9 -mfpu=neon -DEMBED -Dlinux -D__linux__ -Dunix -fPIC --sysroot=/media/gautam/rootfs/ xiSample.cpp -o xiSample -lm3api -pthread
/usr/lib/gcc-cross/arm-linux-gnueabi/5/../../../../arm-linux-gnueabi/bin/ld: error: xiSample uses VFP register arguments, /usr/lib/gcc-cross/arm-linux-gnueabi/5/crtbegin.o does not
/usr/lib/gcc-cross/arm-linux-gnueabi/5/../../../../arm-linux-gnueabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc-cross/arm-linux-gnueabi/5/crtbegin.o
/usr/lib/gcc-cross/arm-linux-gnueabi/5/../../../../arm-linux-gnueabi/bin/ld: error: xiSample uses VFP register arguments, /usr/lib/gcc-cross/arm-linux-gnueabi/5/crtend.o does not
/usr/lib/gcc-cross/arm-linux-gnueabi/5/../../../../arm-linux-gnueabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc-cross/arm-linux-gnueabi/5/crtend.o
collect2: error: ld returned 1 exit status
gPats
Tags (2)
