Petalinux u-boot build fail
I opened the I2C command in the uboot configuration, but I didn't compile it.Can I replace my existing version of uboot with uboot in the higher version of petalinux?
Or can I see exactly what the error is and print out the detailed fault information?
thank you!
Re: Petalinux u-boot build fail
Hi @fan199821756
It is not recommended to use higher version of u-boot then the version of Petalinux provided.
Can you provide complete error logs?
you can see the complete log in <proj>/build/build.log
Kranthi
Best Regards
Kranthi
Hi @fan199821756
By default in u-boot configuration, the CMD_I2C is enabled. You no need enable it again. Can you please share the steps what you are trying to do. As Kranthi mentioned you should not replace your current version of u-boot into latest petalinux version. Instead you can use latest version of petalinux. and if you want enable any of your design specific configuration you can enable in latest and built it.
Thanks & regards
Aravind
