Petalinux u-boot development
I'm trying to debug a u-boot issue (it doesn't detect mass storage devices) by making modifications to the source code and rebuilding.
I make the changes in build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/ but after running
petalinux-build -c u-boot, the sources are deleted. They appear again after running petalinux-config -c u-boot but my modifications are lost.
I realize I must not be modifying the sources in the right place, but I didn't find the sources in any other directory.
What is the proper workflow for editing source -> rebuild -> test -> edit source -> rebuild and so on?
Is there any documentation on this? I looked through UG1157 and UG1144 but I didn't see this addressed.
thanks
Vicentiu
Re: Petalinux u-boot development
You should use the "out of tree" build if making mods to the uboot
See the Petalinux user guide 2018.2
Or, download the uboot from github, make your mods, compile, then copy to images/linux in your Petalinux project dir. The pertalinux-package
Once You are happy with your mods, then create a patch (git diff xilinx-v2018.2 < 0001_uboot_patch.patch) then add this to your uboot recipe
