Petalinux uboot problem - kernel_image not set
Using Petalinux 2014.2
selecting boot from SD card, kernel image file name = image.ub
When booting from SD card here is what I get from uboot prompt:
U-Boot 2014.01 (Aug 22 2014 - 12:29:34)
Memory: ECC disabled
DRAM: 1 GiB
MMC: zynq_sdhci: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
U-BOOT for 2d227_bare_system
Gem.e000b000 Waiting for PHY auto negotiation to complete..... done
BOOTP broadcast 1
DHCP client bound to address 10.0.0.129
Gem.e000b000:0 is connected to Gem.e000b000. Reconnecting to Gem.e000b000
Gem.e000b000 Waiting for PHY auto negotiation to complete....... done
*** Warning: no boot file name; using '0A000081.img'
Using Gem.e000b000 device
TFTP from server 10.0.0.106; our IP address is 10.0.0.129
Filename '0A000081.img'.
ENV :
U-Boot-PetaLinux> printenv
autoload=no
baudrate=115200
bootcmd=run default_bootcmd
bootdelay=4
clobstart=0x01000000
console=console=ttyPS0,115200
default_bootcmd=tftp ${netstart} ${kernel_img} && bootm ${netstart}
dnsip=10.0.0.3
dtbnetstart=0x02800000
ethact=Gem.e000b000
ethaddr=00:0a:35:00:ae:ba
fault=echo ${img} image size is greater than allocated place - partition ${img}
is NOT UPDATED
gatewayip=10.0.0.3
hostname=2d227_bare_system
ipaddr=10.0.0.129
loadaddr=0x01000000
nc=setenv stdout nc;setenv stdin nc;
netboot=tftp ${netstart} ${kernel_img} && bootm
netmask=255.255.255.0
netstart=0x01000000
psserial0=setenv stdout ttyPS0;setenv stdin ttyPS0
sdboot=echo boot Petalinux; mmcinfo && fatload mmc 0 ${netstart} ${kernel_img} &
& bootm
serial=setenv stdout serial;setenv stdin serial
serverip=10.0.0.106
test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${im
g} is NOT UPDATED; fi
test_img=setenv var "if test ${filesize} -gt ${psize}; then run fault; else run
${installcmd}; fi"; run var; setenv var
Environment size: 1060/16380 bytes
U-Boot-PetaLinux>
Obviously kernel_img is not set, so setting this in uboot to image.ub (like in petalinux config) and then running boot command, it works...
In 2013.10 kernel_img was set by default to image.ub and there was no problem
Is this a bug , or is there a specific configuration I must do ?
Re: Petalinux uboot problem - kernel_image not set
In 2014.2 it is now needed to specify that the SD card is being used in multiple places.
Double-check that the following are configured for SD card:
MenuConfig --> Subsystem AUTO Hardware Settings --> Advanced bootable images storage Settings --> boot image settings
MenuConfig --> Subsystem AUTO Hardware Settings --> Advanced bootable images storage Settings --> kernel image settings
this space intentionally left blank
