Visitor borikgor
Petalinux: user-apps won't build
Hi, guys.
I need some help here:
I'm working with a QEMU of the Petalinux on an Atlys BSP:
Linux version 3.3.0
Digilent-Atlys-AXI-XUP-14.2
It's my Student project, to run an application on the Petalinux..
I'm trying to make a simple "Hello, World" application for Petalinux and following all the steps, described in the 'Application Development and Debugging Guide'.
Just creating an application and trying to build the image of the petalinux fails with the following:
borisg@Project:~/Petalinux/software/petalinux-dist$ petalinux-new-app bapp
New application template successfully created in /home/borisg/Petalinux/software/user-apps/bapp
See bapp/README for what to do next.
borisg@Project:~/Petalinux/software/petalinux-dist$ make appconfig
[INFO ] Validating system configuration
[INFO ] Saving previous build.log
[INFO ] Building ucfront tool
[INFO ] Building kernel
[INFO ] Building u-boot
[00:00] / /bin/sh: Bad substitution
make: *** [u-boot] Error 2
I have no idea, on what to make of this.. :(
Can somebody, please, help me out here?
Let me know, if any additional data may help.
Re: Petalinux: user-apps won't build
1. Check this link http://forums.xilinx.com/t5/Embedded-Linux/U-boot-make-Error-in-petalinux/td-p/301037
2. Try #sudo dpkg-reconfigure dash
--HS
--HS
Visitor borikgor
Thanks, mate.
Will check and get back with an answer.
Visitor borikgor
I've tried both tips, but none helped me..
1. Reseting the configuration file, as described in the linked topic
2. Changing the Dash to Bash
Both resulted in the same output on the 'make' command:
Any additional help is appreciated.
What do you get if you run the following command?
$ ls -l /bin/sh
Tags (3)
Visitor borikgor
Got it!
Thanks guys, now the switch in my head turned to the right position! :)
I was using Dash.
After changing to Bash, by declining the request of the "sudo dpkg-reconfigure dash" command, I (my OS) was able to compile the application and fnish the make process.
Thanks a lot, guys for your invaluable help!
Good to see that you got over this. We have implemented a warning into PetaLinux to detect dash and guide users towards using bash.
Visitor borikgor
Well, sadly I haven't seen that warning..
Another thing, that's bugging me:
Petalinux uses 'ash', which is neither 'bash', nor 'sh'.
How much the ash differs from bash?
Or is it a stupid question and 'ash', being the base of the busybox, is fully configurable?
Scholar vanmierlo
If the scripts require bash, then why not modify their shebang to indicate that? Then the users don't have to modify their host and there is no need for the warning which leads to failure later on anyway. Xilinx, please replace #!/bin/sh with #!/bin/bash in the appropriate (generated?) scripts.
