Observer rjmoss
Petalinux v2018.2 building fsbl hangs at do_configure stage at "repo -set $path" call in app.tcl
Host OS:  Ubuntu 16.04.5
Petalinux: v2018.2
Board/BSP: xilinx-zcu102-v2018.2-final.bsp
I have been unable to build the v2018.2 FSBL of PMU Firmware with petalinux v2018.2 and can't figure out why.
The do_configure stage for both hangs indefinitely.  Checking the configure logs show:
DEBUG: Executing shell function do_configure
MISC_ARG is  -yamlconf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/fsbl.yaml
APP_ARG is  -app "Zynq MP FSBL"
cmd is: xsct /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/app.tcl -ws /xilinx/petalinux/v2018.2/projects/zcu102_base/build/../components/plnx_workspace/fsbl -pname fsbl -rp /xilinx/petalinux/v2018.2/tools/hsm/data/embeddedsw -processor psu_cortexa53_0 -hdf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/deploy/images/zcu102-zynqmp/Xilinx-zcu102-zynqmp.hdf -arch 64  -app "Zynq MP FSBL"  -yamlconf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/fsbl.yaml
Display is :142
Starting xsdk. This could take few seconds... Picked up _JAVA_OPTIONS: -Duser.home=/xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/xsctenv
done
XSCTHELPER INFO: Empty WorkSpace
{channel "tcfchan#0" closed} {-code 1 -level 0 -errorcode NONE -errorinfo {channel "tcfchan#0" closed
    while executing
"::tcf::send_command $chan $service $cmd [list sdk_command_callback]"} -errorline 12}
Eclipse:
GTK+ Version Check
MISC_ARG is  -yamlconf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/pmu-firmware/2018.2+gitAUTOINC+6e82c0183b-r0/pmu-firmware.yaml
APP_ARG is  -app "ZynqMP PMU Firmware"
cmd is: xsct /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/pmu-firmware/2018.2+gitAUTOINC+6e82c0183b-r0/app.tcl -ws /xilinx/petalinux/v2018.2/projects/zcu102_base/build/../components/plnx_workspace/pmu-firmware -pname pmu-firmware -rp /xilinx/petalinux/v2018.2/tools/hsm/data/embeddedsw -processor psu_pmu_0 -hdf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/deploy/images/zcu102-zynqmp/Xilinx-zcu102-zynqmp.hdf -arch 32  -app "ZynqMP PMU Firmware"  -yamlconf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/pmu-firmware/2018.2+gitAUTOINC+6e82c0183b-r0/pmu-firmware.yaml
Display is :125
done
    while executing
Eclipse:
GTK+ Version Check
It appears that this error occurs in both of the packages in the app.tcl when it calls:
repo -set $path
Any ideas on what might be causing this would be helpful.
Here are the steps to recreate:
$ mkdir -p /xilinx/petalinux/v2018.2
$ /srv/software/xilinx/petalinux/petalinux-v2018.2-final-installer.run /xilinx/petalinux/v2018.2
$ cd /xilinx/petalinux/v2018.2
$ source settings.sh
$ mkdir projects
$ petalinux-create -t project -n projects/zcu102_base -s /srv/software/xilinx/bsps/xilinx-zcu102-v2018.2-final.bsp
$ cd projects/zcu102_base
$ petalinux-config
	- Set the following:
	-> Image Packaging Configuration
		-> tftpboot directory = /srv/tfptboot/v2018.2/zcu102_base
	-> Yocto Settings
		-> Parallel thread execution
			-> BB_NUMBER_THREADS = 4
			-> PARALLEL_MAKE = 4
		-> Local sstate feed settings
			-> local sstate feeds url = /srv/sstate-mirrors/sstate-rel-v2018.2/aarch64
$ petalinux-build -c fsbl
[INFO] building fsbl
[INFO] sourcing bitbake
INFO: bitbake fsbl
Loading cache: 100% |#####################################################################################################################################| Time: 0:00:00
Loaded 3437 entries from dependency cache.
Parsing recipes: 100% |###################################################################################################################################| Time: 0:00:03
Parsing of 2552 .bb files complete (2513 cached, 39 parsed). 3441 targets, 138 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |################################################################################################################################| Time: 0:00:00
Checking sstate mirror object availability: 100% |########################################################################################################| Time: 0:00:00
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
Currently  1 running tasks (617 of 627)  98% |#######################################################################################################################   |
0: fsbl-2018.2+gitAUTOINC+6e82c0183b-r0 do_configure - 1605s (pid 19530)
Re: Petalinux v2018.2 building fsbl hangs at do_configure stage at "repo -set $path" call in app.tcl
Did petalinux-build working for you? Can you also try petalinux-build -c bootloader?
Observer rjmoss
Petalinux seems to be working fine for anything that doesn't rely on the FSBL or PMUFW (unfortunately the bootloader is tied to FSBL in Petalinux).
It actually looks like what's causing the problem is related to XSCT in some way, but I don't now enough about what goes on in the background to begin to understand what's missing.  I can call XSCT directly with the same commands that the Petalinux FSBL recipe uses during the configure stage of the FSBL source and see the same thing.
Prep clean source:
$ petalinux-build -c fsbl -x distclean
$ petalinux-build -c fsbl -x unpack
$ petalinux-build -c fsbl -x create_yaml
$ pushd build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c01
83b-r0/
Setup the environment (manually)
(same as Petalinux recipe)
$ export RDI_PLATFORM=lnx64
$ export SW_GTK3=0
$ export 'AP_ARG= -app "Zynq MP FSBL"'
$ export 'MISC_ARG= -yamlconf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/fsbl.yaml'
$ export PATH=/xilinx/petalinux/v2018.2/tools/hsm/bin:$PATH
Run the XSCT command manually
$ xsct /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/app.tcl -ws /xilinx/petalinux/v2018.2/projects/zcu102_base/build/../components/plnx_workspace/fsbl -pname fsbl -rp /xilinx/petalinux/v2018.2/tools/hsm/data/embeddedsw -processor psu_cortexa53_0 -hdf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/deploy/images/zcu102-zynqmp/Xilinx-zcu102-zynqmp.hdf -arch 64 -app "Zynq MP FSBL" -yamlconf /xilinx/petalinux/v2018.2/projects/zcu102_base/build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/fsbl.yaml
Starting xsdk. This could take few seconds... Eclipse:
GTK+ Version Check
done
   while executing
If I add some additional output messages to the fsbl app.tcl file around the call to 'repo -set $path'...
147:		if { $params(rp) ne "none" } {
148:			#Local Repo Available, Set repo path. Or will pick it up from build
149:			set path [split $params(rp) { }]
150:			puts "+repo -set $path"
151:			repo -set $path
152:			puts "-repo -set $path"
153:		}
It shows the call to repo is what's not returning...
GTK+ Version Check
done
+repo -set /xilinx/petalinux/v2018.2/tools/hsm/data/embeddedsw
    while executing
It looks like the next step is to dig into xsct and see what this script is calling and where that might lead - I suspect a host configuration issue, but just need to peel the onion a bit more.
Jason
Visitor ffcs
I 'm having the same error, using zcu106 bsp.
anybody can tell me how to fix it?
Visitor ffcs
It seems my os lost some package in gtk2.0
I reinstall gtk2.0 .
It works fine.
Visitor galentx
I had precisely the same issue using Ubuntu server 16.04.5 and, taking the suggestion by ffcs, installed GTK 2 and 3:
$ sudo apt install libgtk-3-dev
$ sudo apt install libgtk2.0-dev
My build attempt after installing version 3 still hung, so I think it was installation of 2.0 that made the difference. My guess is that Xilinx's testing of Ubuntu 16.04 was done on the desktop version, which probably includes GTK in the base configuration, so GTK didn't make the list of prerequisites.
Visitor bobwmcgrath
this did it for me too with petalinux 2017.4.1 and the zybo bsp
Hi @rjmoss@ffcs
Could you please mark the solution post of this thread as an accepted solution, that will help others looking for the similar answer
Best Regards
Shabbir
Observer clarkchris
I confirmed that libgtk2.0-dev is required for petalinux-build. Thanks for the tip, @ffcs and @galentx!
@shabbirk, please ask for this dependency to be added to UG1144 Table 2-1.
I built a Docker image for building petalinux using Ubuntu 16.04 as the base, and I found these other dependencies that are not listed in UG1144:
  • cpio
  • language-pack-en
  • lsb-release
Hi @clarkchris,
We haven't mentioned that we support building petalinux using Docker. This is something we haven't decided to support.
But you need GUI packages to build petalinux. We are working on this to address all the GUI package dependencies to documented in 2018.3.
Other issues we see is there are number of desktop environment available for each Linux distro but we wanted to limit this support for Gnome/KDE but this still in discussion.
Current petalinux tools are tested with GUI/Sever with Desktop/Desktop environment
Sandeep
