Petalinux v2019.1 fails to compile glib-2.0
When trying to build a Petalinux project, the build fails on glib-2.0. This is reproducible for me even after reinstalling Petalinux, deleting the sstate-cache and build folders, recreating the project, and also between different OS versions (Ubuntu 18.04 and Ubuntu 16.04).
Bitbake output when building only glib-2.0:
source /opt/xilinx/petalinux-v2019.1/settings.sh && LANG=en_US.UTF-8 petalinux-build -c glib-2.0
PetaLinux environment set to '/opt/xilinx/petalinux-v2019.1'
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution
[INFO] building glib-2.0
[INFO] sourcing bitbake
[INFO] generating user layers
INFO: bitbake glib-2.0
Loading cache: 100% |###########################################################################################################################| Time: 0:00:01
Loaded 3811 entries from dependency cache.
Parsing recipes: 100% |#########################################################################################################################| Time: 0:00:02
Parsing of 2777 .bb files complete (2775 cached, 2 parsed). 3812 targets, 150 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |######################################################################################################################| Time: 0:00:01
Checking sstate mirror object availability: 100% |##############################################################################################| Time: 0:00:00
Sstate summary: Wanted 103 Found 4 Missed 198 Current 513 (3% match, 83% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: glib-2.0-1_2.58.0-r0 do_install: oe_runmake failed
ERROR: glib-2.0-1_2.58.0-r0 do_install: Function failed: do_install (log file is located at <snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/temp/log.do_install.1171)
ERROR: Logfile of failure stored in: <snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/temp/log.do_install.1171
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/automake/automake_1.16.1.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb:do_populate_sysroot', '/op
t/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-support/libffi/libffi_3.2.1.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-support/bash-completion/bash-completion_2.8.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-gnome/gtk-doc/gtk-doc_1.29.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64
/layers/core/meta/recipes-core/glibc/glibc_2.28.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-core/gettext/gettext_0.19.8.1.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/gnu-config/gn
u-config_git.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-core/util-linux/util-linux_2.32.1.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-core/zlib/zlib_1.2.11.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components
/yocto/source/aarch64/layers/core/meta/recipes-devtools/gcc/gcc-cross_8.2.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/autoconf/autoconf_2.69.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/quilt/quilt-native_0.65.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-ext
ended/xz/xz_5.2.4.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-core/dbus/dbus_1.12.10.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-support/libpcre/libpcre_8.42.bb:do_populate_sysroot', 'virtual:native:/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-core/glib-2.0/glib-2.0_2.58.0.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/c
omponents/yocto/source/aarch64/layers/core/meta/recipes-devtools/gcc/gcc-runtime_8.2.bb:do_populate_sysroot', '/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-devtools/python/python3-native_3.5.6.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['automake-native', 'pkgconfig-native', 'libtool-native', 'libffi', 'bash-completion', 'gtk-doc-native', 'glibc', 'gettext-native', 'pseudo-native', 'gnu-config-native', 'util-linux', 'libtool-cross', 'zlib', 'gcc-cross-aarch64', 'autoconf-native', 'quilt-native', 'xz-native', 'dbus', 'libpcre', 'glib-2.0-native', 'gcc-runtime', 'python3-native', 'texinfo-dummy-native', 'linux-libc-headers', 'gettext-minimal-native', 'libxcrypt', 'opkg-utils', 'libpam', 'ncurs
es', 'binutils-cross-aarch64', 'mpfr-native', 'libmpc-native', 'zlib-native', 'gmp-native', 'flex-native', 'm4-native', 'expat', 'autoconf-archive', 'base-files', 'initscripts', 'shadow', 'update-rc.d', 'base-passwd', 'shadow-sysroot', 'shadow-native', 'libx11', 'libsm', 'bzip2', 'libpcre-native', 'util-linux-native', 'libffi-native', 'libgcc', 'readline-native', 'openssl-native', 'sqlite3-native', 'gdbm-native', 'bzip2-native', 'flex', 'cracklib', 'attr', 'xtrans', 'util-macros', 'xorgproto', 'libxcb', 'l
ibice', 'lzo-native', 'ncurses-native', 'xcb-proto', 'libpthread-stubs', 'libxdmcp', 'libxau']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: SITE files ['endian-little', 'bit-64', 'arm-common', 'arm-64', 'common-linux', 'common-glibc', 'aarch64-linux', 'common']
| DEBUG: Executing shell function do_install
| NOTE: make -j 8 DESTDIR=<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image install
| make  install-recursive
| make[1]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build'
| Making install in .
| make[2]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build'
| make[3]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build'
|  <snip>/sw/build/tmp/hosttools/mkdir -p '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/bin'
|  <snip>/sw/build/tmp/hosttools/mkdir -p '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/share/glib-2.0/valgrind'
|  <snip>/sw/build/tmp/hosttools/mkdir -p '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/libexec/installed-tests/glib'
|  <snip>/sw/build/tmp/hosttools/mkdir -p '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/lib/pkgconfig'
|  <snip>/sw/build/tmp/hosttools/install -c glib-gettextize '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/bin'
|  <snip>/sw/build/tmp/hosttools/install -c -m 644 glib-2.0.pc gobject-2.0.pc gmodule-2.0.pc gmodule-export-2.0.pc gmodule-no-export-2.0.pc gthread-2.0.pc gio-2.0.pc gio-unix-2.0.pc '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/lib/pkgconfig'
|  <snip>/sw/build/tmp/hosttools/install -c -m 644 ../../../../../../../../../../../../../../<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/glib-2.58.0/glib.supp '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/share/glib-2.0/valgrind'
| make[3]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build'
| make[2]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build'
| Making install in m4macros
| make[2]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/m4macros'
| make  install-am
| make[3]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/m4macros'
| make[4]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/m4macros'
| make[4]: Nothing to be done for 'install-exec-am'.
|  <snip>/sw/build/tmp/hosttools/mkdir -p '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/share/aclocal'
|  <snip>/sw/build/tmp/hosttools/install -c -m 644 ../../../../../../../../../../../../../../../<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/glib-2.58.0/m4macros/glib-2.0.m4 ../../../../../../../../../../../../../../../<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/glib-2.58.0/m4macros/glib-gettext.m4 ../../../../../../../../../../../../../../../<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/glib-2.58.0/m4macros/gsettings.m4 '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/share/aclocal'
| make[4]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/m4macros'
| make[3]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/m4macros'
| make[2]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/m4macros'
| Making install in glib
| make[2]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib'
| make[3]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib'
| Making install in libcharset
| make[4]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib/libcharset'
| make  install-am
| make[5]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib/libcharset'
| make[6]: Entering directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib/libcharset'
| /bin/sh /install-sh -d <snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/image/usr/lib
| /bin/sh: /install-sh: No such file or directory
| make[6]: *** [Makefile:1514: install-exec-local] Error 127
| make[6]: *** Waiting for unfinished jobs....
| make[6]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib/libcharset'
| make[5]: *** [Makefile:1335: install-am] Error 2
| make[5]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib/libcharset'
| make[4]: *** [Makefile:1329: install] Error 2
| make[4]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib/libcharset'
| make[3]: *** [Makefile:2622: install-recursive] Error 1
| make[3]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib'
| make[2]: *** [Makefile:2947: install] Error 2
| make[2]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build/glib'
| make[1]: *** [Makefile:1262: install-recursive] Error 1
| make[1]: Leaving directory '<snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/build'
| make: *** [Makefile:1731: install] Error 2
| ERROR: oe_runmake failed
| WARNING: <snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/temp/run.do_install.1171:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_install (log file is located at <snip>/sw/build/tmp/work/aarch64-xilinx-linux/glib-2.0/1_2.58.0-r0/temp/log.do_install.1171)
ERROR: Task (/opt/xilinx/petalinux-v2019.1/components/yocto/source/aarch64/layers/core/meta/recipes-core/glib-2.0/glib-2.0_2.58.0.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1829 tasks of which 1804 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build glib-2.0
Makefile:41: recipe for target 'build-glib-2.0' failed
make: *** [build-glib-2.0] Error 255
Re: Petalinux v2019.1 fails to compile glib-2.0
I've managed to solve this. In case anyone has the same problem, it was due to the project foldering being inside a symlinked folder. cd'ing to the real full path without symlinks and rebuilding everything fixed it.
Hi @isaacjt
We are not seeing any issues after enabling glib-2.0 in rootfs and building petalinux project with 2019.1 bsp.
