Petalinux with meta-linaro rootfs
I wanted to ask you guys if there is a way to construct a linaro rootfs and use it as default rootfs using meta-linaro in petalinux 19.1 or 20.1?
-Ciprian
You can add external Yocto layers in addition to the generated meta-user in a PetaLinux project so you should be able to add meta-linaro (see p. 81 "Adding Layers"):
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1144-petalinux-tools-reference-guide.pdf
I'm not familiar with the Linaro images, but if they have image recipes in that layer, you should be able to include (via "require" statement) by making a petalinux-user-image.bbappend file in your project
https://www.yoctoproject.org/pipermail/yocto/2011-December/004024.html
Ken Sloat - Embedded Software Engineer
https://www.designlinxhs.com
Thank you for the reply,
I managed to add the layer and to build it using the layer... I now curious if you can replace the default rootfs with the meta-linaro one.
-Ciprian
If it's in the Linaro meta layer then you should be able to do:
petalinux-build -c <linaro-rootfs-recipe-name>
PetaLinux builds, configures and generates "petalinux-user-image" by default so unless you specify as above then the typical commands are performed on this image.
