Petalinux/yocto preferred version
In petalinux-config -c rootfs I would like to install opencv however, selecting the package automaltically sets preferred version to latest. I would like to use:
PREFERRED_VERSION_opencv ="2.4"
 but I am unsure which project file should this be included into? as most of the conf files are automatically generated.
Re: Petalinux/yocto preferred version
Hi @ziladdev,
Which version of petalinux are you using?
In 2018.x petalinux/yocto rocko release it is shipped with opencv 3.3 http://cgit.openembedded.org/meta-openembedded/tree/meta-oe/recipes-support/opencv/opencv_3.3.bb?h=rocko
You can't use 2.4 as suggested by @shabbirk it is blacklisted from Yocto community http://layers.openembedded.org/layerindex/recipe/54289/
Sandeep
Try adding in project-spec/meta-user/conf/petalinuxbsp.conf
Best Regards
Shabbir
Hi @ziladdev,
Sandeep
Yes, in the end we moved on to 3.1. It was indeed that the recipe was blacklisted.
