Petalinux1802 failed to source bitbake under Ubuntu1804
1,Source Petalinux settings.sh then comes an error like below in red sign
PetaLinux environment set to '/home/ubt/Documents/petalinux1802'
INFO: Checking free disk space
INFO: Checking installed tools
environment: line 281: ((: 10#15~1 > 10#3: syntax error in expression (error token is "~1 > 10#3")
environment: line 285: ((: 10#15~1 < 10#3: syntax error in expression (error token is "~1 < 10#3")
INFO: Checking installed development libraries
INFO: Checking network and other services
2, If Ignore above issue then comes bitbake issue
ubt@ubt:~/Documents/Petalinux_prj/ptp_l2midV3$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
ERROR: Failed to source bitbake
ERROR: Failed to build project
My OS info.:Linux ubt 4.15.0-32-generic #35-Ubuntu SMP Fri Aug 10 17:58:07 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Petalinux Version: petalinux-v2018.2-final-installer.run
Is there anybody get those issue too? Please give me a favor, thank you all.
Re: Petalinux1802 failed to source bitbake under Ubuntu1804
Hi @washingtonxr,
Ubuntu 18.04 is not support for 2018.x release. , Please use ubuntu-16.04.
Please follow installation requirements as per this link:https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf  (page no:9)
Thanks & regards
Aravind
Forget about using anything other than 16.04 LTS. I tried getting it to work on 18.04 for days to no avail.
Hi @kautschuk,
Yocto community doesn't support Ubuntu 18.04 refer https://www.yoctoproject.org/docs/2.4.1/mega-manual/mega-manual.html#detailed-supported-distros and all the meta-* layers are not tested with Ubuntu 18.04.
Sandeep
